Seat Tube Out of Round- Mtbr.com
Results 1 to 16 of 16
    Reputation: GhisalloWheels's Avatar
    Oct 2007
    I am nearly finished with my frame. I have built it up and I am now cleaning up the joints. Playing around, I went to put the seat post in the seat tube. Yep, the seat tube has gone out of round. Any ideas on how to round it out? I could ream it, if I had one but that doesn't seem like the best idea as I will have some slop on the "longer" side of the oval.
    I'm really bummed and exasperated, but I will persist. Any help would be much appreciated.
    Thanks a bunch.
    Cycle tracks will abound in Utopia. ~H.G. Wells
    pvd
    pvd is offline
    Reputation: pvd's Avatar
    Ream.
    Professional MTBR Member
    Sep 2017
    You could mill the seatpost to match the gimp seat tube. Just need a 4-axis mill and some 3D contouring CAD/CAM software.
    Or, if you can find a bearing ball that matches the seat tube ID, weld a bar to the ball and hammer it in. You'll need the welded bar to remove the ball.
    Then ream.
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Quote Originally Posted by EricTheDood View Post
    Now that's a novel idea. Have you done this before?
    Eric
    If I don't make an attempt, how will I know if it will work?
    Sep 2017
    Quote Originally Posted by Eric Malcolm View Post
    Eric
    On tubing, no. In solid machined parts, yes.
    It's not uncommon to "burnish" a precision bore with relatively cheap bearing ball, especially in a thru-hole.
    Bal-tec - Report On Ball Sizing
    Oct 2007
    Thanks for all the ideas. I have an old seat post that is the same size. I may try to reround the tube by gentling hammering that into the tube then see if I can ream it after. I will be using a dropper post so if its not super smooth going in and out its not a deal breaker.
    Reputation: life behind bars's Avatar
    May 2014
    Quote Originally Posted by GhisalloWheels View Post
    Save yourself seizing a seatpost in the frame and ream it out.
    "These things are very fancy commuter bikes or really bad dirt bikes, but they are not mountain bikes." - J. Mac
    Guest
    I'd think about slugging it like a rifle barrel (small spherical steel slug on a rod). Grease it and drive it in and out to round the tube. Alternately you could make an oval slug and twist it around the tube pushing it lower with each turn.
    Ream it.
    Myth Cycles handbuilt bike frames
    Durango, CO
    http://www.mythcycles.com
    Moderator Moderator
    Reputation: Walt's Avatar
    What on earth is this hammering advice? Seat tubes are *always* ovalized after you weld them or braze them. Always. You ream them back to round. Period.
    -Walt
    mbtr member
    Reputation: scottzg's Avatar
    All the above is true, but if you totally pood the screwch and have a wacky seat tube you're better off putting in a shim. Although reaming the seat tube is part of building a frame, if it's totally fuct up cuz it's your first frame and your metalworking sucks... it's easy to ream so much the seat tube ends up so thin it cracks in short order.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Oct 2007
    My local bike shop has a "burnishing tool". I will try that first. I went back and did some additional investigation and it doesn't seem as bad as I originally thought. Crossing my fingers that will be enough.
    Thank you all for your input. It's much appreciated.
    Hopefully pictures of finished frame will be posted within the month. (Kitchen renovation must take priority if I want to stay married.)
    Reputation: Feldybikes's Avatar
    Adjustable reamers work reasonably well and are pretty cheap. In this case, you don't need to spend hundreds on a specialty tool.
    I would think you could find one for closer to $30, but here's a link to one on ye olde amazon
    I guessed you wanted this size based on using a dropper post. It should work for 30.9 or 31.6 posts. Get the next size down if you are using a 27.2.
    Oct 2007
    Quote Originally Posted by Feldybikes View Post
    Thanks. Thats perfect.
    Sep 2017
    Quote Originally Posted by Walt View Post
    -Walt
    Why remove material when you can reform it and maintain wall thickness?
    Moderator Moderator
    Have you ever forcibly reshaped a welded joint made from thin tubing? It's a great way to cause it to fail either immediately or a bit later when you're riding the bike. Hammering a big steel ball through the seat tube... the mind boggles. You are almost certain to wreck your frame.
    I've reamed something like 750 seat tubes at this point - the same way pretty much every other builder reams seat tubes, since forever. It works great. The tools are cheap and easy to use, and it's fast. Assuming you did an even halfway decent job of selecting tubes and joining them, the material you remove poses no danger to the integrity of the frame. Hammering something through the joint, on the other hand...
    Look, I know you were trying to be helpful here. But you don't know what you're talking about. There's a simple, proven, safe process to accomplish what the OP wants to accomplish.
    -Walt
  1. Weehoo iGo 2 - square tube kickstand on older round tube chassis
    By mauric6943 in forum Families and Riding with Kids
    Last Post: 06-09-2017, 10:54 AM
  2. When is "round" not round??
    By slohr in forum Singlespeed
    Last Post: 05-26-2016, 06:43 PM
  3. Oval to round to oval to round to...
    By Lenny7 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-28-2015, 07:11 PM
  4. Seat tube, top tube, head tube deal
    By calstar in forum Frame Building
    Last Post: 08-29-2013, 10:12 AM
  5. Seat tube - "out of round"
    By Ratman in forum Frame Building
    Last Post: 04-06-2011, 09:41 PM
