seat tube collar help- Mtbr.com
Results 1 to 3 of 3
    Ipso Facto
    Reputation: bikecycology's Avatar
    hello,
    I am looking at the PMW seat collars that allow you to use straight gauge tubing for a seat tube and this collar reduces for the proper ID for the seat post. I know that pretty much all of the examples that I have seen have been welding in (probably fusion welded). Do you think that I will have any luck brazing one in that has the step down? I was thinking about putting brass or silver rings inside the tube and drawing it out through the joint with the torch. Thoughts?
    Thanks, Wil
    Moderator Moderator
    Reputation: Walt's Avatar
    You can silver braze it just like you would a lug. If you're concerned about penetration or inexperienced with silver, just drill a few (tiny) holes through the straightgauge tube so you can see where the silver has progressed to (or even feed silver through the holes).
    Go for it!
    -Walt
    Ipso Facto
    excellent! Thanks Walt
  1. Replies: 0
    Last Post: 07-31-2014, 09:09 AM
  2. Replies: 1
    Last Post: 10-14-2013, 09:43 AM
  3. Seat tube, top tube, head tube deal
    By calstar in forum Frame Building
    Last Post: 08-29-2013, 10:12 AM
  4. Carbon frames: Seat tube collar aligned or opposite the slit?
    By gibbons in forum Bike and Frame discussion
    Last Post: 11-05-2011, 01:21 PM
  5. Finally found QR seat collar in the UK
    By cumbriajason in forum Ibis
    Last Post: 10-25-2011, 12:17 PM
