seat collar question- Mtbr.com
    Ipso Facto
    Reputation: bikecycology's Avatar
    I have a seat collar that I want to braze in to a seat tube. I was thinking a coil of brass and sweat it through the joint. I know silver would be better/easier but I am concerned about a later process when I braze the top tube and seat stays to the seat tube near by. I worry that the silver will leave the area. Any thoughts on what I should do? Anyone with experience with this?
    Frame Building Moderator
    Reputation: Walt's Avatar
    Both will work fine. Things will re-melt some when you go to join the toptube and stays, but the joint isn't going to move around or come apart (if you don't believe me, try getting a tube out of a lug sometime...).
    If your fit is pretty tight, you might have a hard time getting the brass to actually flow through. But I bet it will work fine.
    -Walt
    Reputation: Meriwether's Avatar
    Definitely would use silver for that but i bet bronze could work fine. Like Walt said, don't worry about re heating up the silver in the next process. Could always use a nickel silver or System 48 wire and 56 for the later one
    mbtr member
    Reputation: scottzg's Avatar
    Brain fart.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
  1. Replies: 3
    Last Post: 08-28-2018, 12:05 AM
  2. Replies: 0
    Last Post: 07-31-2014, 09:09 AM
  3. Thomson seat post collar/clamp fitting question
    By Paranoid_Android in forum 29er Components
    Last Post: 06-22-2012, 03:21 PM
  4. question about seat collar size.
    By derekdehaas in forum Frame Building
    Last Post: 05-21-2008, 10:16 AM
  5. Blue collar or white collar?
    By RomSpaceKnight in forum Riding Passion
    Last Post: 10-24-2006, 09:31 PM
