Rust in steel frame issue?- Mtbr.com
Results 1 to 3 of 3
    Hey.
    Got some rust in the BB shell of my chromag surface steel frame.
    Here is a picture.
    Is it a bug issue?
    And what product/method can I use to get rid of it?
    Thanks heaps!
    Reputation: Feldybikes's Avatar
    By issue, do you mean, "is my frame about to rust through?" Then I'd say no, not an issue. I'd say it's time to spray some framesaver/boeshield/rust inhibitor of your choice in there (hell, has anyone tried WD 40?)
    I drill drain/vent holes in the bottom of my bottom bracket shells. Then again, I live where the trail is usually dry and the air is dry, too. This is a matter of open debate. Not necessarily recommending it, but it's an option.
    Rent this space for $
    Reputation: Oh My Sack!'s Avatar
    I'd wire brush the loose stuff, clean it out, then dose it with one of the above mentioned products. I use CorrosionX HD Marine. It's a product I have used for years for extensive applications on boats in the nasty saltwater marine environment. It works very well for frame applications. I dosed my Karate Monkey frame when it was brand new by spraying it into all the tubing drain holes and BB and orienting the frame so that it would run throughout the interior of the tubing.
  1. Removing rust from steel frame interior
    By disease in forum Vintage, Retro, Classic
    Last Post: 03-13-2015, 04:34 PM
  2. Maintaining Steel Frames (Rust Prevention)
    By maxwolfie in forum Bike and Frame discussion
    Last Post: 02-26-2015, 06:50 PM
  3. Anti-rust treatment for steel
    By solitone in forum Frame Building
    Last Post: 04-19-2013, 01:01 PM
  4. Maintanance of steel and rust?
    By tangaroo in forum Fat bikes
    Last Post: 11-02-2012, 08:42 AM
  5. Steel Frame & Rust
    By lostinNH in forum Bike and Frame discussion
    Last Post: 07-03-2011, 04:25 PM
