Repair crack 4130- Mtbr.com
Results 1 to 5 of 5
    VRG
    VRG is offline
    Reputation: VRG's Avatar
    May 2013
    Repair crack 4130
    Hello.
    A couple of days ago, I found a crack on my bike. Help advice.
    I can not choose the filler rod. Which is better for repair? ER70S-2 or ER80S-D2.
    Thanks in advance.
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    I cannot help you with the rod selection, I am a braze type of guy.
    I would suggest to you that if you Tig this and add a strip of metal along the lower edge to add to the repair, it will add a bit of stress relief to overall repair.
    Eric
    If I don't make an attempt, how will I know if it will work?
    VRG
    VRG is offline
    May 2013
    Quote Originally Posted by Eric Malcolm View Post
    Eric
    I agree to the idea of adding a strip of metal. Do you mean brazing?
    If brazing, then I worry a little. Does brazing not damage the weld? Melting point 1166 F
    Sorry for my english
    Plays with tools
    Reputation: customfab's Avatar
    First step with a production bike is to investigate your warranty options.
    Assuming that's not an option, is it just a pin hole or is there a crack propagating from the hole? If it's just a hole, that's definitely a weld defect but might not ever cause a problem. It's been there since it was new, so the fact that the frame is 7 years old and it hasn't started to crack gives more reason to just keep an eye on it. Holes like that in the middle of a weld don't ever appear once the weld has solidified. They either pop up when the weld is still molten or not at all. If there is a crack along with the hole, 70s-X is a good choice. I'm not sold on the idea of adding extra material as I don't think it's a design flaw, just poor execution.
    VRG
    VRG is offline
    May 2013
    Quote Originally Posted by customfab View Post
    ...is it just a pin hole or is there a crack propagating from the hole?
    ok thanks, I will use 70s-X.
    I made this hole myself to stop the crack.
    I have no complaints about welds, they are excellent on my frame. Perhaps this is just metal fatigue, or poor design chainstay yoke.
  1. HELP!! carbon frame crack or just paint crack??
    By long1002 in forum Custom Builders & Other Manufacturers
    Last Post: 05-02-2015, 09:08 AM
  2. Frame crack or just a paint crack?
    By MartinAir in forum General Discussion
    Last Post: 07-04-2013, 06:49 PM
  3. SIR 9 Paint Crack or Frame Crack??
    By AaronJobe in forum Niner Bikes
    Last Post: 01-04-2013, 10:19 AM
  4. paint crack or frame crack?
    By fujibikeben in forum Frame Building
    Last Post: 10-16-2011, 07:53 PM
  5. Frame crack or paint crack?
    By Rad Rider 415 in forum Niner Bikes
    Last Post: 05-06-2011, 07:20 AM
