Which primer for steel- Mtbr.com
Results 1 to 6 of 6
    Dec 2017
    Hi there,
    my paint shop suggested me to use bi-component primer for my steel frames. The guy only said that bi-component is always better than mono component.
    Durability wise is there a real difference? I can't really find any info on that.
    On top of the primer I will use acrylic paint and clear coat, both bicomponent.
    2k (bi-component) paint and primer are higher performance paints and there will be a durability difference. On a bicycle application, I don't think a 2k primer is necessary. I use an acid etch primer coat on the bare steel to "seal" it and then spray a high build primer coat over the top that you can sand flat if there are any rough areas. SEM and several other manufacturers make these in a rattle can and they lay nice and flat on clean steel, especially the acid etch.
    But....if you already have a spray gun set up with a larger fluid tip for primer, a 2k primer wouldn't hurt!
    Dec 2017
    Quote Originally Posted by FullTiltBoogie View Post
    Thank you, very informative. Do you think a 2k primer will contribute to a better chipping resistance, or that is only a function of the upper coats?
    That is a good question that I don't know the answer to! Using two component paint/primer will increase "durability" because the second component is an activator or hardener. But I'm not exactly sure what the word "durable" means in reference to 2k vs. 1k because it seems the automotive paint industry places a lot of value on protection from chemicals, weather, and UV. In talking to paint reps, there is never much mention of impact resistance. If I had to guess, Id say the difference would be negligible.
    Single(Pivot)and Happy
    Reputation: Boulder Pilot's Avatar
    Durability of a primer? Some primers adhere to bare metal better than others. Some primers sand better than others. All primers will fail if surface prep is compromised. I do not know of a primer that has the ability to add strength to a top coat.
    The suspension of your bike sucks if it's different than mine. Really. It sucks. Big time.
    Reputation: bakerjw's Avatar
    Oct 2014
    I always use automotive DTM 2k primers. The one that I've been using lately is HiTeck epoxy DTM. It is a high build primer.
    As stated, surface prep is the key.
    Help chart the mountains at www.appalachianbiketrails.org
  1. Replies: 9
    Last Post: 07-22-2017, 07:28 PM
  2. Replies: 4
    Last Post: 04-24-2017, 02:26 PM
  3. Is a steel frame a steel frame, a steel frame?
    By coffeegeek2112 in forum Bike and Frame discussion
    Last Post: 10-21-2007, 12:43 AM
  4. Is a steel frame a steel frame, a steel frame?
    By coffeegeek2112 in forum Frame Building
    Last Post: 10-20-2007, 10:54 PM
  5. Classic Steel bikes, which tubing is better. (Steel lovers only)
    By Cmonster in forum Vintage, Retro, Classic
    Last Post: 11-04-2005, 10:14 PM
Members who have read this thread: 4
