Please help me understand geometry equivalence- Mtbr.com
    This might seem silly to y'all experienced builders, but I cannot wrap my head around the fact that brands like Kona can come up with frames like the Wozo with a TT length of 630mm and call it a medium, whereas Ventana has el Gordo with a TT length of 588mm.
    What should I pay attention to? Is it the ST angle, HT length? Is it the fact that the Kona uses a larger diameter tire front vs. back? Please help me understand a bit of frame design.
    Kona:
    KONA BIKES | MTB | FATBIKE | Wozo
    Ventana:
    http://www.ventanausa.com/images/bik...art-090517.pdf
    pvd
    pvd is online now
    Reputation: pvd's Avatar
    We use front center to understand bikes. Stack and reach to see if we can fit a cockpit. and seat tube length to know if we can fit a dropper.
    Top tube length doesn't mean anything.
    Oct 2017
    Estuche
    if you dig on this thread and others you will find a wealth of info on geometry. pinkbike has had a couple decent articles as well. This has been said by others here as well . You can't just look at the frame from one length or angle it is all the dimensions that will make up the bikes characteristics.
    if you compare each of the given dims of those bikes they are different at the st&ht angles, bb drop, fork lenght, HT lenght and so on. Every bike company or frame builder is using dims to achieve a certain goal for what the bike will be like once finish. It is hard to say which is right if the end goals are different. Keep digging for info on characteristics and effects of geometry. Use the free bikecad version and start plugging in bike companies geos or your own with all the dimension on screen and you can see why one TT lenght , reach, stack , ht lenght ,angles , bb drop will make a difference.
    Andrew Cooper
    Bicycle Fabrication Supply - Let's Build More Bikes
    bikefabsupply.com
    This is truly helpful, many thanks!!
  1. Help me understand frame geometry.
    By Tincup69 in forum Fat bikes
    Last Post: 09-10-2015, 01:07 PM
  2. Help me understand geometry specs
    By Texasbubba in forum 29er Bikes
    Last Post: 08-10-2015, 11:35 AM
  3. Trying to understand this unseen bike's geometry
    By simonsez in forum 29er Bikes
    Last Post: 05-30-2013, 04:25 PM
  4. Geometry questions: help me understand
    By tootall in forum 29er Bikes
    Last Post: 09-10-2012, 05:21 PM
  5. Help me better understand bike geometry
    By SoWal_MTBer in forum Bike and Frame discussion
    Last Post: 07-14-2012, 09:16 PM
Members who have read this thread: 4
