PF92 Bottom Bracket Shell Source?- Mtbr.com
Results 1 to 5 of 5
    Reputation: Feldybikes's Avatar
    Does anyone know where I can get a PF92 bottom bracket shell, preferably in aluminum? Paragon has a few left in steel and Ti, but these are made undersized and they're being phased out anyway.
    pvd
    pvd is offline
    Reputation: pvd's Avatar
    I was making PF41/92 shells for years before Paragon started. They're easy enough to make but I've been buying the PMW since because they are nice.
    How are they being phased out? PF41 is the best system put there. I've heard nothing of this.
    My backup will be to make one on my FNC* benchtop Atlas. Just looking for the easy button since I'd have to order material anyway.
    *That's Feldy Numeric Controlled
    Quote Originally Posted by pvd View Post
    I mean phased out by Paragon, not the industry in general:
    Quote Originally Posted by Paragon website
    This 4130 steel bottom bracket shell is designed specifically for the 41 mm press-fit type bottom brackets. The outside diameter is 1-3/4" x 93.5 mm wide, providing 1.5 mm for facing after welding. The inside diameter is supplied .5 mm undersized to 40.5 mm (1.595"), and must be finished to size after fabrication by the frame builder. It is relieved in the center for weight reduction to 42 mm (1.653").
    DISCONTINUED STYLE, ALL SALES FINAL.
    Item sold individually.
    pvd
    pvd is offline
    WTF. This is insane.
    Someone ask Paragon to knock out the BB392EVO shells.
    For those scratching their head...it's a BB92 width shell that accepts PF30 bearings.
  1. Xx1 eagle bb30 crank on pf92 bb shell? Fuel ex 9.9
    By hiss2 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-06-2018, 05:28 AM
  2. Replacing top fuel 9.8 PF92 bottom bracket
    By ShortTravelMag in forum Trek
    Last Post: 07-11-2017, 07:15 PM
  3. Replacing a Shimano MTB HT II bottom bracket with a Shimano Road HT II bottom bracket
    By AndrwSwitch in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2015, 11:58 AM
  4. Shimano PF92 bottom bracket
    By newrider6 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-28-2014, 06:16 PM
  5. Convert PF92 BB shell to threaded?
    By Sparticus in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-07-2014, 06:55 PM
