No drill bottle bosses- Mtbr.com
Results 1 to 7 of 7
    With the age of longer dropper posts, does anyone make a braze-on no drill bottle boss? I'd like to add a set to my seatpost and make sure that I don't have to drill any extra holes in my frame.
    If it doesn't already exist (I've tried looking) what do you experts and amateurs think would be a minimum bolt length for holding a bottle cage on a frame? I'm considering making something myself and silvering it onto the seat toob.
    Reputation: Clockwork Bikes's Avatar
    Shorten up some rack braze-ons and use them. Or braze a short bolt to the frame and use a nut on top of the cage--some old frames have this.
    NOTHING WORKS LIKE CLOCKWORK
    www.clockworkbikes.com
    pvd
    pvd is offline
    Reputation: pvd's Avatar
    pvd
    pvd is offline
    hmmm, for some reason I forgot to look at PMW catalogue . . . . . (insert funny Homer Simpson image here) . . . . . .
    Thanks PVD
    Dec 2012
    You could also do a sort of post mount bottle boss, using some small tube and a standard bottle boss. Braze a 1/2" (or whatever you need) piece of tube at 90 degrees to the seat tube, and put the bottle boss at the end.
    mbtr member
    Reputation: scottzg's Avatar
    Those are awesome, thanks for the heads-up!
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
  1. Stuck Chainring bolt...to drill or not to drill?
    By bsgerig in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-17-2013, 05:55 PM
  2. to drill or not to drill, that is the queation
    By nmn25 in forum Downhill - Freeride
    Last Post: 03-11-2008, 04:40 AM
  3. to drill or not to drill? that is the question
    By nmn25 in forum Shocks and Suspension
    Last Post: 03-10-2008, 10:14 PM
  4. To drill or not to drill
    By KmCowham in forum Alaska
    Last Post: 02-16-2008, 01:56 AM
