New project: Laminated wood mountain bike- Mtbr.com
Results 1 to 41 of 41
    Reputation: wardo78's Avatar
    Apr 2005
    New project: Laminated wood mountain bike-20180803_091548-x2.jpg
    After successfully building and riding my wooden gravel bike earlier this year (http://forums.mtbr.com/gravel-bikes/...e-1066231.html ), I decided to take on a wooden mountain bike frame. It will be a modern geometry (slack, long top tube) 27.5+ frame. It is formed by laminating 12-5mm lamello's, 6 per half. Subsequently, the frame tubes are formed by routing out the inside and rounding over/sculpting the exterior. Given the intended use, the frame is significantly reinforced with carbon/Kevlar hybrid cloth between the laminates and the inside of the frame tubes are lined with two layers of carbon fiber cloth. I expect the frame to weigh in around 6.5 pounds, not light, but I know from my gravel bike that it will ride lighter than the numbers indicate, with a nice balance of compliance and rigidity. The wood is walnut on the outside, one layer of cherry, then ash. Thanks to Vermont Plank Flooring for hooking me up!
    Thanks,
    Wardo
    will rant for food
    Oooo subscribed.
    If you build your own stuff you know that the frame doesn't even need to be light, it's the light components that make more of a riding difference.
    Apr 2005
    Quote Originally Posted by Drew Diller View Post
    Oooo subscribed.
    That is true. My gravel frame is just around 6 pounds, and the total bike weighs 21. It is a dream to ride, and is literally my favorite gravel/road bike of all time. I suspect this will be much the same.
    Wardo
    Oct 2013
    Nice! Is that purpleheart? I love the stuff, but it's both gummy and abrasive on the CNC tooling.
    Apr 2005
    Quote Originally Posted by armyofevilrobots View Post
    Walnut, which has ideal properties for a bicycle frame. It has a good weight to torsional rigidity ratio. Purpleheart actually looks pretty good in this regard as well, but I don't like working with it as well. I prefer local hardwoods although I do have a thing for Sapele. Here is an excellent website that discusses some of the engineering concerning using wood in bicycle frame construction: https://ligneusbikes.wordpress.com/w...-talk-numbers/.
    Wardo
    Reputation: J.B. Weld's Avatar
    It doesn't seem very practical. Other materials seem better suited for the job. I love it!
    I brake for stinkbugs
    650b me
    Reputation: golden boy's Avatar
    Thanks for posting, keep us updated on your progress. I'm intrigued by wood bicycle frames. I'd love to ride one, I bet you can really feel the difference vs. metal.
    Interplanetary Poultry
    Reputation: scatterbrained's Avatar
    Ooooooh. This is going to be good.
    Editor In Chief, "Internet Tough Guy Magazine"
    "Home of Chuck Norris' Keyboard"
    Reputation: life behind bars's Avatar
    May 2014
    This gives me wood. Pun intended.
    "These things are very fancy commuter bikes or really bad dirt bikes, but they are not mountain bikes." - J. Mac
    Oct 2013
    Cool. Walnut is pretty sturdy as well.
    As an aside, when I built my hickory and purpleheart handlebars, I stumbled upon this paper from the US forestry service:
    https://www.fpl.fs.fed.us/documnts/f...tr113/ch04.pdf
    It has some neat mechanical properties of a _vast_ number of different species of wood.
    will rant for food
    Your what now?! Post pictures!
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    Oh Boy, did someone mention Handlbars........
    If I don't make an attempt, how will I know if it will work?
    Oct 2013
    Handlebars.
    New project: Laminated wood mountain bike-handlerbars_1.jpg
    The two compound bends were a PITA.
    IIRC; it's 820mm wide, 3 deg backsweep and upsweep.
    380G or so.
    will rant for food
    Man that is friggin sweet. Great job.
    Apr 2005
    380G or so.
    Nice! I thought of making bars, but haven't gotten around to it.
    Ward
    Oct 2013
    Quote Originally Posted by wardo78 View Post
    Ward
    That's funny. I've been meaning to make a wooden bike, but... well... you can guess
    Reputation: slowrider's Avatar
    That bar is solid wood? I've seen catastrophic carbon bar failures, how do you re-enforce single tube, wooden bar to take such stresses?
    Looks amazing but I'd be scared to ride it.
    Apr 2005
    Quote Originally Posted by slowrider View Post
    Although I can't speak specifically to evil robots bars, I can tell they are solid bar formed from laminates. They are likely steamed then put on a bending form. Once they have cooled, the laminates are put back on the form with adhesive, I am guessing epoxy. The process creates a very strong structure, there is tension between the laminates that adds rigidity, and by having different layers, you reduce the chance that it will fail along a grain line since each laminates grain pattern if different.
    Wardo
    Oct 2013
    Wardo78 nailed it. There are 70 pieces of wood in that lam-up, although, while solid, the thicker area contains a section of cedar at the center which is much lighter than the hickory and purpleheart.
    Oddly, this is the third bar I created, and the glue used here is actually weld bond III between the laminates (although it has a coating of system III epoxy on the exterior). In testing, the weld-bond was actually stronger. In any case, the bond always failed in the wood instead of in the glue itself. I suspect the weld bond penetrates the wood better than the epoxy, and reinforces the bond boundary.
    Also, this bar flexes FAR less than my ~250 gram Chromag OSX downhill bar. The first two were tested to failure, and the second failure test was weighted on one side with a very significant drop that actually bent the stem it was clamped in. While the test wasn't up to normal safety testing rigor, I am not concerned about getting injured using it as an XC/cruiser bar.
    Apr 2005
    70 lams is considerable! I am interested by your glue results. I use epoxy not because I have tested it, but because it is what boat builders use and over the years I have learned to work with it. I use Weld Bond III for most of my normal projects, so I am glad to hear it performs so well!
    Ward
    Reputation: phattruth's Avatar
    This is a great thread, I love wood bikes. I remember seeing a Renovo road bike a number of years ago and thinking I need to make one. The tubes were massive. I've been working on my design for a while now. Many years of research and several design iterations have lead to this. I'm currently working on perfecting the tool paths for my CNC router. This version doesn't show all of the fillets that will be on the final product as they not going to be included in the tool paths.
    New project: Laminated wood mountain bike-29_27.jpg
    The Truth will set you free.
    ....but it might offend you first!
    Apr 2005
    Quote Originally Posted by phattruth View Post
    I elected to take the opposite tack. I researched for a week, designed for a day and was riding my gravel bike 4 weeks later. I am not fluent in CAD, nor CNC, plus having spent years developing my pattern and jig making skills, these make sense for one off, or very limited production projects. If I were making a significant number of frames CNC would totally be my choice. How are you planning to bend the stays? Are you going to laminate the rest of the frame? What woods are you considering? I had to take a significant break from my project because I had an allergic reaction to the walnut sawdust, but I should have the frame ready for sanding by the end of this weekend.
    Wardo
    Apr 2005
    After the extended hiatus due to my walnut sawdust allergic reaction, I am back at it. At this point, the frame is basically structurally complete, so final sanding and then finish application are next. With any luck it should be ready to be built up in a week. Here are pics as of today:
    New project: Laminated wood mountain bike-20180831_104755-xl.jpg
    New project: Laminated wood mountain bike-20180831_104809-xl.jpg
    New project: Laminated wood mountain bike-20180831_104915-xl.jpg
    Wardo
    Wardo
    My plan is to laminate both stays. The seat stays and top tube are one piece. I'm going to make a handful of these and I'm looking to make them from oak, maple, ash and hickory. The plan is to make the first one out of doug fir with really thick walls as I can work out the bugs easier in a softwood. I will be machining all weekend to complete the first one.
    Wardo
    Really nice work!
    Apr 2005
    I look forward to seeing the results!
    Wardo
    Apr 2005
    Although there are a few things that need to be resolved, it looks complete and I was able to ride it around a bit. I will wait to get some miles on it before I try to determine if it is a success or not. First impressions are that it rides like a mountain bike should, that the stand over is a bit high for my stature, but I knew that was going to be tough. I wanted to use a longish head tube to reduce the likelihood of structural failure, and that pushed the top tube up a bit. It weighs more than I anticipated (7+ lbs for the frame), but again I was structurally conservative... although it is only as strong as it's weakest bit, so it may be overbuilt in the wrong areas. I'll report back when it has a few real rides on it. Here are some pics:
    New project: Laminated wood mountain bike-20180907_180455-xl.jpg
    New project: Laminated wood mountain bike-20180907_180427-xl.jpg
    New project: Laminated wood mountain bike-20180907_180845-xl.jpg
    wardo
    Apr 2005
    Did you make headway on the project?
    Wardo
    650b me
    Congratulations, Wardo! Time will tell if the ride is to your liking, but it is certainly an aesthetic triumph! Love it!
    Reputation: sturge's Avatar
    That is beautiful! Truely a work of art. Good luck with it.
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...
    will rant for food
    Dang! Well done.
    Personally, I wouldn't ride that. I'd hang it on my wall! That is gorgeous.
    Apr 2005
    Quote Originally Posted by scatterbrained View Post
    Thanks, I built it to ride and that I will!
    Ward
    Apr 2005
    Today, I took the new whip on a two hour ride on a trail system I know well and has an eclectic array of climbs, descents and technical features. I was delighted to be riding a mountain bike frame that I built from scratch, so that put a little spunk in my spin and of course my perspective is biased. At 28.5 pounds, it is the heaviest hard tail I have owned in a long time, but I had already adjusted my expectations from my usual racier hard tail to trail oriented one, and judged by the latter criteria it fit the bill perfectly. The wood frame is quite stiff laterally, but dampens some of the smaller chop. It climbed in and out of the saddle well and the rear wheel hooked up on the slippery bits. Interestingly, the head angle looks a bit steeper from the saddle than the 27.5+ bike it replaces. I am not sure why this is, the wheelbase, angles etc match the previous frame as was my intention. Maybe the rockers in the rear raise it up a tad (although I believe I accounted for this), or maybe it is just a visual illusion due to the taller head tube and thicker frame overall. It really doesn't matter as the real test is how it rode, and here I was very satisfied. It tracked sweepers well, flicked in the tight stuff and didn't feel pitchy on the drops. The headset loosened up a bit (probably the lower cup settling in a bit) so there was a tiny clunk on descents that had my stopping to do a safety inspection. A good start for the two of us, the pic is the bike meeting some of it's cousins.
    Wardo
    New project: Laminated wood mountain bike-20180909_125806-xl.jpg
    Apr 2005
    I dragged the fleet of wooden bikes out for a family portrait as well. The balance bike is for my grandson, but it is his Christmas present so it is living with us until then.
    Wardo
    New project: Laminated wood mountain bike-20180909_161424-xl.jpg
    New project: Laminated wood mountain bike-20180909_161626-x2.jpg
    Upcyclist
    Beautiful bike(s), Wardo!
    I do a bit of woodworking myself, but that's on another level!
    By continuing to browse my posts, you agree to accept my use of cookies.
    Apr 2005
    Quote Originally Posted by Cornfield View Post
    Building a wooden frame isn't that difficult if you have the right tools and the time. Mostly it takes the Chutzpah to just start!
    Wardo
    Reputation: kyle_vk's Avatar
    Do you have any process photos of the balance bike? I've got a 3 month old at home and work at a millwork shop, so I've got enough time to mess a few try's up before he's old enough to ride one
    Apr 2005
    Quote Originally Posted by kyle_vk View Post
    Sorry, I didn't take any pictures of the process. I basically took the dimensions off an existing bike, drew up some plans, made a form the matched the plans, cut the laminates and glued them up. The "chain" stays were done seperately and glued on after the main spar was drilled for the seat post and headset. It is really pretty easy if you are handy... it took me a few days of part time fiddling.
    Wardo
    Apr 2005
    A couple of better pictures:
    New project: Laminated wood mountain bike-20180721_163702-x2.jpg
    New project: Laminated wood mountain bike-20180721_163716-xl.jpg
    New project: Laminated wood mountain bike-20180721_163734-xl.jpg
    Wardo
    Thanks, i appreciate it! Looking forward to your next project!
  1. Replies: 84
    Last Post: 08-19-2018, 12:52 PM
  2. Homebrew laminated wood balance bike
    By wardo78 in forum Families and Riding with Kids
    Last Post: 07-31-2018, 01:14 PM
  3. New Superlight 29 Project - Project Monsterlight 29
    By pointerDixie214 in forum Santa Cruz
    Last Post: 01-15-2016, 12:56 PM
  4. Wet wood is Slippery Wood
    By mtnryder56 in forum California - Norcal
    Last Post: 03-31-2013, 04:45 PM
  5. Replies: 2
    Last Post: 10-05-2011, 11:34 AM
Members who have read this thread: 21
