Multiple headtubes on one frame?- Mtbr.com
Results 1 to 17 of 17
    Discussion over in the families and kids forum got me thinking -- has anyone ever tried making a frame with multiple headtubes with a short piece / pieces of tubing welded in between as a spacer to make one frame "fit" more than one size?
    For a smaller rider / smaller wheel size, you'd put the headset and fork in the headtube closer to the rider. As they get older you could move everything to the front headtube to increase the reach & stack.
    A well-designed insert could let you use the spare headtube as storage for a multitool or snacks.
    Is there something I'm missing that would make this a terrible idea or reasons why I can't find any instances of anyone trying it?
    Jan 2019
    A framebuilder here in the uk called Robin Mather made something similar, tho not for the same purpose. Worth taking a look at
    Some pics here
    https://www.bespoked.cc/Photo%20gall...binmather.html
    Wanna ride bikes?
    Oct 2013
    Interesting concept.
    Here's a pic from the link hillm posted. Holy what the?!?!
    SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Jan 2019
    yeah its cool. I think he built it to be able to test out different geo's. Also has some sort of analogue read out that gives some information about the riding. I cant remember where i read that so i could be totally wrong hah.
    Wanna ride bikes?
    Oct 2013
    Yeah, I can't figure out everything that's going on in that pic. It looks like there's some kind of push-pull device that goes from the steering to the rear end but for what? Also the second chainring on the NDS, what the what? Don't forget the 12 different front axle positions, not to mention the multiple headtubes. Oh the possibilities...
    SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Cycologist
    Reputation: chazpat's Avatar
    Looks like the second chainring on the NDS drives a roll of paper that is recording like a seismograph, providing info on flex on various tubes of the frame.
    This post is a natural product. Variances in spelling & grammar should be appreciated as part of its character & beauty.
    since 4/10/2009
    Reputation: Harold's Avatar
    I don't think it's frame flex. I think it's recording steering inputs. But the mechanism seems pretty complicated to do so, so I think it's related to stability of riding the bike with different geometries. It almost seems like there's some sort of steering damping of sorts going on, as I don't think the stem clamps straight to that intermediate steerer tube of sorts.
    What I can't figure out is the lever arm that drops vertically down from the seatstay lever. It looks like it's connected to the same apparatus that records steering inputs, but why, I dunno.
    Quote Originally Posted by Harold View Post
    Is it dragging the ground to try to detect if the rear wheel leaves the ground?
    Trail Ninja
    Reputation: Varaxis's Avatar
    Looks like it measures bike lean and steering yaw.
    The design itself seems to decouple HA from all other things that people attribute to HA: reach, ETT, cornering feel, steering directness/stability, front center, etc.
    For example, someone might ignorantly say that they wouldn't ride a 90 degree HA bike, as they fear it would be much more OTB prone and twitchy. That is more a function of a too short front center (distance between the BB and front axle). The twitchiness is a function of the front wheel's "mechanical trail"--it has multiple front wheel mounting locations (fork offset) to adjust the steering feel. Having the contact patch behind/trail the fork's steering axis gives it stability.
    In essence, the HA's role is reduced to determining the front axle path. If it were a telescoping fork, any force acting on it that isn't along its axis would be translated to harshness and flex.
    "The challenge is not in developing new ideas, but in escaping old ideas."
    Wanna ride bikes?
    Oct 2013
    Quote Originally Posted by Varaxis View Post
    The twitchiness is a function of the front wheel's "mechanical trail"--it has multiple front wheel mounting locations (fork offset) to adjust the steering feel. Having the contact patch behind/trail the the fork's steering axle gives it stability.
    On this subject, would I be right in thinking that the bike would handle the same (assuming flat pavement) and not know the difference of wether the fork is completely in front of the front wheel and offset to the rear (as pictured) as opposed to a typical steel fork which is either inline or offset to the front of the fork? (this assumes the wheelbase is the same)
    SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Wanna ride bikes?
    Oct 2013
    As a side note I like that the steering looks to be connected from the steer tube attached at the handlebars to the forks steertube by a belt under the lower headset cup.
    Not too often you have to clarify which steer tube and headtube you're referring to.
    Next up, steering axis, inclines, declines, wheelbase, and.. OH Dammit I just burst a vein in my brain.
    SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    MethHeadCycles
    Pro Crastinator
    Quote Originally Posted by *OneSpeed* View Post
    in other pics, they are directly connected together with a tie-rod...
    Attached Thumbnails Attached Thumbnails Multiple headtubes on one frame?-exibid_2f5a0387.jpg
    Cycologist
    Looking at the linkage at the top of that vertical rod, it is designed to move vertically and then translate that movement horizontally when recording on the paper. I'm starting to think this was just an art project.
    Pro Crastinator
    not to mention, the kickstand looking thing is welded into place and would hang up on everything under the sun. this was never intended to be ridden...
    Cycologist
    Poking around (ie: googling) looks like a financial company now owns his domain (wtf?)
    But I found this caption under a photo:
    Bike with adjustable head angle and trail with 3 channel analogue data recorder.
    https://www.flickr.com/photos/781526...n/photostream/
    Cycologist
  1. Tapered Headtubes and Steerer tube ?
    By Evil4bc in forum Frame Building
    Last Post: 07-10-2011, 01:11 AM
  2. Tapered headtubes with 1 1/8 forks
    By phoeneous in forum Shocks and Suspension
    Last Post: 06-22-2011, 07:56 PM
  3. FS Tapered headtubes
    By 18bikes in forum Frame Building
    Last Post: 02-18-2011, 02:48 AM
  4. 1.5 Paragon headtubes
    By mattty in forum Frame Building
    Last Post: 02-08-2011, 07:34 PM
  5. Do Lefties Fit in Fatty Headtubes?
    By Ginga in forum Cannondale
    Last Post: 01-31-2011, 12:42 PM
Members who have read this thread: 72
