Modular Dropouts and ISO Disc Tabs- Mtbr.com
    Jul 2016
    I'm about to start working on the backend of my first build. I'm using the shimano modular dropouts that you can find on most frame building supply sites. I went to mock everything up using my open source feng shui tab locator and it seems like the ISO tab will hang off the backend of the modular dropout flanges. Anyone dealt with this before?
    Dec 2012
    Yup. You need to use a post mount, if you want to attach to the seat stay. For IS mount, you can attach to the chain stay and bend the seat stay to make clearance for the caliper.Modular Dropouts and ISO Disc Tabs-27074959579_17a2172219_c.jpg
    Oct 2017
    Redoctober , You can check out our post mount tabs at bikefabsupply.com , the E36 model is made to go between the chainstay and seat stay. other options are available as well . I have used the E44 and E45 post tabs with the modular dropouts for both 160 and 180 mounting
    David , that frame looks great by the way
    Andrew Cooper
    Bicycle Fabrication Supply - Let's Build More Bikes
    bikefabsupply.com
    Dec 2012
    Quote Originally Posted by Andrew Coooper View Post
    Thanks, Andrew.
  1. Replies: 6
    Last Post: 09-12-2011, 07:24 AM
  2. paul dropouts and disc tabs...
    By Kam in forum Frame Building
    Last Post: 09-30-2008, 12:31 PM
  3. Mount Vision's Modular Dropouts XC ---> AM
    By emassa15 in forum Marin
    Last Post: 09-11-2008, 05:53 PM
  4. Titus Riddler SS Rear Disc Modular Dropouts
    By SanAnMan in forum Singlespeed
    Last Post: 12-09-2004, 12:32 PM
  5. Replies: 2
    Last Post: 04-19-2004, 12:29 PM
