Joining/extending aluminium tube- Mtbr.com
Results 1 to 8 of 8
    Humour me...... If I had an aluminium tube and I wanted to make it 2" longer, what are the options for doing such a thing?
    In my head, the obvious thing would be to cut the tube and internally sleeve it etc
    My plan is then to encase it in carbon.
    Any guidance on this would be ace
    A bit more info required really. What shape tube? Strength required? Why encase in carbon? Whats going on the end of the extension? etc......
    As in make these longer...
    Sent from my CLT-L09 using Tapatalk
    Yes, I love a weird project! Maybe make an entire new extended dropout with a long insert to go in the existing leg and bond it in. You could convert to a more modern axle at the same time. Id avoid welding unless you know a friendly heat treatment plant, cost is very prohibitive.
    The axle is where I became a little unstuck.
    I'd contemplated buying a carbon rigid fork with a 15mm bolt through and disc mount attached, then somehow sticking the pair of twats together
    I don't know how, but I'm practical and happy to research
    I'm a plumber so if this was copper.....
    Something like this perhaps? With a non boost 15mm axle and disc mount already attached???
    I'm aware this is bizarre, but I've committed now
    can you take pictures of the existing dropout, i presume its a round tube.
    If you want a disc mount as well i think i'd be fabricating a metal dropout like these MRP forks, and then sliding it over the existing tubes and bonding in place.
    https://mrpbike.com/pages/rigid-fork-comparison
  1. Replies: 4
    Last Post: 01-18-2019, 07:41 AM
  2. Extending travel on 2009 Reba
    By Captain_America1976 in forum 29er Bikes
    Last Post: 04-18-2011, 09:24 AM
  3. extending a lefty?
    By packfill in forum Cannondale
    Last Post: 04-06-2011, 05:30 PM
  4. Lockon grips extending out of the bar?
    By LoneReaction in forum Beginner's Corner
    Last Post: 02-15-2011, 09:13 AM
  5. Extending Steerer Tube
    By Jizmo in forum Shocks and Suspension
    Last Post: 08-24-2004, 08:58 AM
