Internally routing hoses + cables- Mtbr.com
Results 1 to 3 of 3
    May 2013
    Folks,
    What size stainless tubing are you using to route hydraulic hoses and shifter cable?
    Looks like 5/16" automotive brake line with a .028" wall results in a .257" (6.5mm) ID. I assume that should be fine so long as I'm not running any tight bends.
    -T-
    The 5/16" you mention would probably be perfect. Since I only do short pieces (dropper routing entrance for example) I usually use an even thinner wall 1/4" stainless tube.
    Myth Cycles handbuilt bike frames
    Durango, CO
    http://www.mythcycles.com
    May 2013
    It's ordered.
    Now to botch some frames!
  1. Replies: 2
    Last Post: 07-25-2016, 11:39 AM
  2. Internally routed cables for shifters - how to fit?
    By puiufly in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-29-2015, 05:06 AM
  3. Replies: 9
    Last Post: 11-23-2014, 11:06 AM
  4. Internally routed cables
    By def156 in forum Frame Building
    Last Post: 03-18-2011, 03:00 PM
  5. Cables, Cables and More Cables
    By Ultra Magnus in forum Weight Weenies
    Last Post: 01-21-2005, 10:28 PM
