HTA changes.- Mtbr.com
Results 1 to 6 of 6
Thread: HTA changes.
    Aug 2015
    HTA changes.
    If I didn't show up lit to math in high school I may be able to figure this out. I posted here because I need a frame builders math.
    I have a HT with a 100mm fork with a 70.25 HTA. If understand correctly and install a 120mm fork that will slacken he HTA by 1degree. Would this be static or after the 5-7 mm extra sag?
    So the head tube would end up rising 20mm static. If I put a 1 degree head set to slacken it then how much would that lower the head tube?
    Would the head tube be close to original height? Static or after sag?
    I have seen posts about angle headsets but no one seems to mention how this drops the front down.
    Am I making sense?
    pvd
    pvd is offline
    Reputation: pvd's Avatar
    Aug 2015
    I did say I spent high school math lit up didn't I?
    Not a role model
    Reputation: ninjichor's Avatar
    Jul 2018
    You got measuring tools?
    Right Triangle Calculator and Solver
    Maybe calculator 4 would work for you, if you have the A2C lengths of each fork, and you can confirm your confusion regarding static vs sag by measuring your current setup.
    Most Delicious
    Reputation: dr.welby's Avatar
    Try this tool to compare changes:
    https://bikegeo.muha.cc/
    Reputation: Feldybikes's Avatar
    Quote Originally Posted by rlee View Post
    Am I making sense?
    To answer your last question: sorta, but not really.
    What's you're underlying concern? That the bars be at exactly the same height? It's unclear to me if the point of the angleset is for it's own sake (i.e. you really want to slacker the bike even more) or if you are just trying to lower the bars back to their original height.
    (Side note: I'm not sure what bike that has a >70 HA also has a headtube sized to take an angleset, but I guess it's plausible)
    You seem to have a reasonably good grasp of the numbers themselves and what does what given that you (self-described) don't understand any of the math behind it. Rather than go through the calculations, maybe it'd be helpful for you to take one more step away from the numbers to get at what your concern really is.
    I make bikes. www.feldybikes.com
  1. Everything changes, nothing changes (Klunking stoke)
    By expatrider in forum California - Norcal
    Last Post: 12-07-2015, 08:59 AM
  2. Replies: 35
    Last Post: 03-24-2014, 09:37 AM
  3. Longer CS + steep HTA or Short CS + slack HTA?
    By maragzner in forum 29er Bikes
    Last Post: 09-16-2013, 06:44 AM
  4. Replies: 196
    Last Post: 04-01-2012, 01:12 PM
  5. small changes, big changes
    By rzozaya1969 in forum Titus
    Last Post: 03-15-2006, 07:57 PM
