How to solder the inner pipe to lay the cable?- Mtbr.com
Results 1 to 5 of 5
    Sep 2018
    Hello!
    Run a solid pipe or solder a pair of tubes from both ends? What metal to take soldering tubes from? If solid, then what is the internal thickness given that the brake cable is 5mm.
    Thank.
    Reputation: life behind bars's Avatar
    May 2014
    One length of tubing is the preferred method. .250 tubing, steel or stainless steel.
    I ncredibly
    M yopic
    B ackstabbing
    A ssholes
    Sep 2018
    Thank. Is it possible to refer to a resource selling this rental and specifically to the pipe. Thank.
    May 2014
    Quote Originally Posted by my name is Luy View Post
    Brake line tubing from the auto parts store might be the easiest to source.
    I ncredibly
    M yopic
    B ackstabbing
    A ssholes
    Jan 2016
    I use 0.250" with 0.028" walled stainless.
  1. Replies: 8
    Last Post: 02-16-2011, 02:09 AM
  2. Giga Pipe Team DH VS Giga Pipe Team SL
    By ironhorse1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-10-2008, 11:17 AM
  3. Wheelbuilding - to solder or not to solder
    By Psycho Mike in forum Wheels and Tires
    Last Post: 03-12-2008, 09:59 PM
  4. Truvativ Giga X Pipe GXP bottom bracket plastic pipe ?
    By chas_martel in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-07-2008, 09:58 PM
  5. Gear inner cable instead of brake cable?
    By bike_freak in forum General Discussion
    Last Post: 07-31-2005, 09:24 AM
Members who have read this thread: 4
