Hooded dropout rotational orientation?- Mtbr.com
    Jul 2016
    Complete greenhorn here! Couldn't find the answer after some digging so asking for help. I am using Paragon's hooded rear dropout (thru axle - DR2065). Is there a correct rotational (around axis of axle) orientation for installation? I know I need to keep left and right dropouts in phase with each other. Thinking in terms of resulting angle of derailleur hanger and how important that is. I see on their drawing they show 128 deg and 61 deg indications. Thanks for any insights or suggestions! Daniel
    pvd
    pvd is offline
    Reputation: pvd's Avatar
    The top plane from the model should be aligned with the bottom bracket for 10mm hanger setback. For 8.5mm (preferred), 3 degrees of rotation above the bb.
    Jul 2016
    Thanks, PVD, for the input. Is the setback a measurement from the vertical? This is my first frame, so all of this is new to me.
    pvd
    pvd is offline
    Setback is the distance from the plane perpendicular to the plane formed by the rear axle and bottom bracket spindle. The length of the hanger and set back are specified by SRAM and Shimano.
  1. KS Lev Rotational PLay
    By WoodstockMTB in forum Shocks and Suspension
    Last Post: 01-19-2015, 03:59 PM
  2. All Terra Hubs Rotational Hum Noise?
    By velveteer in forum Wheels and Tires
    Last Post: 02-03-2013, 11:26 AM
  3. 240 grams rotational or 600 gram static
    By CB2 in forum XC Racing and Training
    Last Post: 03-06-2012, 08:57 PM
  4. Rotational weight thoughts
    By Jaredbe in forum Fat bikes
    Last Post: 10-26-2011, 09:26 AM
  5. Replies: 1
    Last Post: 09-20-2011, 11:47 AM
