Headtube With Integrated Bearing Cups- Mtbr.com
Results 1 to 2 of 2
    Jan 2015
    Hello all! Quick question; does anyone know if there is a company out there that makes a 44mm headtube that has the bearing cups built in or a headset manufacturer that has internal cups not needing a crown race? I want to use a fork for a road build that has a tapered steer tube but does not use a crown race. The lower bearing just goes flush against the fork crown and then stops in the headtube. The fork I would like to use is off a Trek Domane ALR. The reason is because the fork has a lot of clearance for 28mm tires with road caliper brakes. Any ideas or help would be great. Or even if anyone knows of a carbon fork that has plenty of clearance for those size tires. The Moots carbon tapered fork is the best I have seen so far for clearance. Thank you everyone!
    mbtr member
    Reputation: scottzg's Avatar
    what you really need is a lower headset cup designed to work with the trek bearing.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
  1. Columbus integrated headtube
    By 18bikes in forum Frame Building
    Last Post: 12-26-2016, 01:24 PM
  2. Conventional headset on a integrated headtube?
    By bikerbob951 in forum Bike and Frame discussion
    Last Post: 07-12-2014, 12:15 AM
  3. Headtube reamer for integrated 1.5 headset
    Last Post: 03-10-2013, 05:53 AM
  4. BB30 bearing fits on PF30 bearing cups?
    By Tjay in forum Shimano
    Last Post: 07-24-2012, 12:28 PM
  5. BB30 bearing fits on PF30 bearing cups?
    By Tjay in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-24-2012, 12:27 PM
