Head tube rings- Mtbr.com
Results 1 to 22 of 22
Thread: Head tube rings
    Mar 2018
    Head tube rings
    Do you attach head tube rings prior to welding the head tube into the frame, or do you ever do it after the fact?
    If I silver braze the rings on first, how much room do I need between the ring and the nearest tig weld to keep from re-melting the silver? Should I just tig weld the rings on instead of brazing them? I plan to experiment on scrap before doing the real frame, but I'm curious to get yall's advice too.
    Thanks,
    Trevor
    mbtr member
    Reputation: scottzg's Avatar
    I put them on last, with silver.
    I prefer Paragon head tubes for mtb frames. They're faster, barely cost more, and come out really nice.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Mar 2018
    Yeah, I've used the Paragon head tubes on all my frames until now, but this new frame has a 340mm head tube, which is way longer than anything they stock.
    mbtr member
    Quote Originally Posted by Trevor Schweald View Post
    Wow, that's a lot of head tube!
    Road bike for a >6'6 dude?
    My road bikes are built around 405mm CX length forks to help keep the head tube more reasonable... But that extra inch doesn't mean much in your situation I guess.
    Mikhail Kalashnikov
    Mar 2018
    Yeah, I'm 6'8" with disproportionately long legs. It's going to be good to experiment with bikes that actually fit me.
    Frame Building Moderator
    Reputation: Walt's Avatar
    At that length, you don't actually need the ring anyway! Head tube is almost as long as the fork!
    Definitely post some pictures of this monster when you're done!
    -Walt
    mbtr member
    Quote Originally Posted by Walt View Post
    -Walt
    Just to confirm- you would still install a reinforcement ring at the bottom, right?
    I'm interested in what trevor creates too. My own dabbling with building unusually large/small road bikes has lead me to believe that there's a lot of shitty road bikes running around. Riding (mostly unremarkable) road geo that really fits me has been an eye-opener.
    Mikhail Kalashnikov
    No, I wouldn't use a ring at all. In the era of big head tubes, ovalizing one is pretty much impossible. Unless the rider is 400 pounds or it's a tandem or something, there's no reason to bother. I only use rings for decoration if a customer requests them.
    I guess it does depend on the head tube. I typically use 1.25mm wall 44mm ID head treated stuff that is pretty much unkillable. If you're using those old S3 headtubes that True Temper used to make that are like 0.8mm or something, different story.
    -Walt
    -W
    mbtr member
    Ahh that makes sense. I've only done thin wall 1.125 head tubes on road bikes.
    Mikhail Kalashnikov
    Mar 2018
    As requested: photos
    Here's a picture of the finished frame, complete with super-duper long head tube:
    Unfortunately, the draw screw on my Park head tube reamer handle isn't long enough, so I'm trying to figure out how to extend it. I think I'm going to make a angle-iron fixture to carefully weld an extension onto the end.
    Here's the bikecad if you're curious
    The threaded part is some goofy threading but you *might* be able to find a coupling nut that would fit?
    I think that beats anything I've ever built on head tube length.
    -Walt
    Mar 2018
    I have an acme threaded coupling nut and some threaded rod on order from McMaster, and that's definitely going to be my first method before I try butt-welding a couple of rods together.
    Reputation: Feldybikes's Avatar
    Downtube "decal" in the drawing = win.
    I make bikes. www.feldybikes.com
    That thing is awesome! Can you even call it a front "triangle"?
    I also really hope you make that downtube decal for real on the frame.
    Nice work on making a bike too, btw.
    Do you have access to a lathe? It only took me about an hour to make an arbor and bull nose dead center so that I could ream/face the head tube on the lathe using the Park cutters. If the lathe has more than about 18" between centers it should be a go.
    Myth Cycles handbuilt bike frames
    Durango, CO
    http://www.mythcycles.com
    mbtr member
    Your head tube is almost as long as your chainstays!!!
    I hope you'll post up some impressions on the completed bike. I find that stuff fascinating.
    Mikhail Kalashnikov
    Mar 2018
    I definitely plan to follow up with impressions on the ride! It'll definitely be unlike anything I've ever ridden. Here's my current, maxed-out XXL Surly Ogre (they don't make the XXL any more):
    Reputation: Eric Malcolm's Avatar
    Dec 2011
Name:	runabout doodeedoo.JPG
    You're going to put a water bottle on the Head Tube - right?
    Eric
    If I don't make an attempt, how will I know if it will work?
    Yes, a water bottle on the head tube would be the finishing touch.
    As an aside, why such crazy short chainstays? You're practically sitting on the rear axle.
    -Walt
    Reputation: adarn's Avatar
    Good excuse to build tooling for reaming/facing head tubes on the lathe if you've got one.
    Best hour I've ever spent getting that stuff set up.
    Mar 2018
    -Walt
    Ignorance, I guess. Also, that's the chainstay length with the dropouts all the way forward. This frame is a geometry experiment/practice project, so if it's a little bit too much of a wheelie machine, oh well. I need to practice my wheelies anyway.
    Mar 2018
    Anything particular I need to know about setting up a lathe to ream head tubes? Could someone share pictures of their setup? I'm not a great machinist, but working on it.
    I'm imagining I just need a live center on the tailstock end with a large enough cone to support the tube. Do I need any kind of pilot for the cutter on the headstock end, or is the cutter itself sufficiently self-centering? What about the rest of the bike? do I just brace it against the bed of the lathe while the reaming operation is happening?
    Cool. I'll do some head scratching and some drawing and see what I come up with.
    Feb 2012
    Use a drawbar if you install the reamer in the cone of the headstock
    Use a centering cone on the tailstock, could be a drillchuck
    Use a slow speed obviously and lubricant
    Some tape around the headtube to protect paint isn't a bad idea
    It's not always necessary to ream the ID, so a two piece cutter is preferable, then you can use an arbor instead of the cutter and just square the end
    If you retract the headtube never ever let the frame loose contact with the cone on the tailstock or you'll loose the frame
  1. Seat tube, top tube, head tube deal
    By calstar in forum Frame Building
    Last Post: 08-29-2013, 10:12 AM
  2. Reynolds 853: 44mm head tube, 30.9mm seat tube
    By butasan in forum Bike and Frame discussion
    Last Post: 04-07-2012, 10:30 AM
  3. 2012 Air9 Head tube / head set questions
    By Nooge in forum Niner Bikes
    Last Post: 12-27-2011, 03:51 PM
  4. Head tube-down tube weld question
    By namelessontrail in forum Frame Building
    Last Post: 03-26-2011, 02:05 PM
  5. Steerer tube length to head tube length Help please
    By Mailman953 in forum 29er Bikes
    Last Post: 01-05-2011, 11:52 AM
