Frame flex- your perceptions?- Mtbr.com
    mbtr member
    Reputation: scottzg's Avatar
    Meh.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Moderator Moderator
    Reputation: Walt's Avatar
    Unless you are systematically varying just the frame tube diameter (or whatever you want to test) there is no way to use this mass of subjective opinion for anything.
    Every 10% bigger you make the tube roughly doubles it's stiffness (the tube, not the frame). 38mm DT is generally stiff enough for even pretty big riders, but if you like it even stiffer, bump up to 42 or 44.5. Beyond that there's no point unless you're doing something super unusual.
    -Walt
    mbtr member
    Quote Originally Posted by Walt View Post
    -Walt
    There's value in hearing what other people perceive even if there's no hard data attached, especially if you build for other people.
    Mikhail Kalashnikov
    Moderator Moderator
    Bluntly, your bikes and perceptions are all over the map. Could something be gleaned (by you)? Sure. Is your OP a good start to a useful conversation? Not really, especially because different people of the same size/riding style can *like* different amounts of frame flex.
    Comparing different styles/brands/models/sizes of bike, built with different components, using different suspension designs (or none), etc... not the way to start. If you really want to investigate what works *for you* get a set of parts you'll use on each frame, and then build some frames using varying tubing, or configuration but not geometry (ie long fork/short head tube vs short fork/long headtube to get the same stack). Of course, then you'll also need to spend a bunch of time on both setups to really get used them both before you can decide what's preferable.
    -Walt
  1. Opinions, Perceptions, Theories, Proof....
    By Havinfun in forum Off Camber (off topic)
    Last Post: 05-06-2015, 10:50 PM
  2. HD frame flex?
    By lawman1991 in forum Ibis
    Last Post: 01-14-2013, 07:09 AM
  3. Perceptions of wheel sizes from the vertically challenged.
    By trane0605 in forum Beginner's Corner
    Last Post: 01-05-2013, 05:17 PM
  4. Frame flex?
    By FreeCoffee in forum Singlespeed
    Last Post: 12-18-2012, 07:28 PM
  5. Frame flex or just BS?
    By Haus Boss in forum All Mountain
    Last Post: 03-18-2011, 02:02 PM
