Frame #2 - 160mm FS 29er- Mtbr.com
Results 1 to 8 of 8
    Mar 2019
    And frame #2 is done! This time around, I went for a full suspension bike.
    I wanted a high-pivot bike and I wanted to keep it single pivot to simplify maintenance. As it ended up, it's basically a single pivot, but with pullrods to reduce the shock's effective eye-to-eye length in order to be able to package it (kinda) vertically. This only adds 2 additional bearings, bringing the total up to 4 (plus 1 shock bushing, at the lower mount), so the bearing count is still low compared to other designs.
    I designed the kinematics using a homemade spreadsheet, aiming for 100% AS, or a little over, around the sag point in the larger cogs. I was also aiming for as linear a motion ratio as possible ( I ended up with about 6% variation over the whole range).
    The frame is chromoly for both front and rear triangles. I'm not super good at documenting what I do, but I do have a few pics of the build process which I included below.
    Specs:
    ~63 HTA
    ~77 STA
    450mm reach
    ~350mm BB height
    435mm chainstays
    160mm F/R
    Attached Thumbnails Attached Thumbnails Frame #2 - 160mm FS 29er-2019-04-24-15.46.46.jpg
    That's rad. Would love to see a video of the suspension cycling. I can't wrap my head around how the pull rods go without a rocker link.
    Moderator Moderator
    Reputation: Walt's Avatar
    It's neat to see the idler bikes coming back into fashion. I thought I wouldn't see that design again as of 20 years ago, but it's back!
    Great work!
    -Walt
    Mar 2019
    Thanks Walt! It's appreciated.
    Shirk, here's a video of the suspension cycling:
    https://youtu.be/jfdUyta0xNA
    Basically, the pullrods don't move relative to the shock. They're bolted directly together up top at the trunnion mount, and there's a bearing at the lower end where the pullrods connect to the rear triangle.
    will rant for food
    Too cool!
    Apr 2017
    Awesome Build! I want to make a high idler bike for my next build. I used a similar method for the front triangle jig, seems to be a easy and inexpensive way to build a jig. Let us know how it rides!
    Mar 2019
    Yeah the front triangle jig worked super well and was really easy to make.
    I took the bike out to Highland & Burke, as well as a couple of days in local trails, and I'm super happy with how it turned out. The high-pivot rear end and the super slack front make it a real tank, it just wants to plow through everything. Surprisingly, it climbs pretty well; the steep STA keeps weight on my front wheel. I'd even say it's an overall better climber than my old bike, a 2014 Devinci Atlas. Although I can definitely feel the extra drivetrain friction, the slower handling makes it easier to point the bike where I want it to go, and I haven't had any issues with wheel flop. I'm super happy with it so far!
    Dec 2011
    Damn that's a cool build. Way to go.
  1. Pike 29" 160mm and 26" 160mm: same internals?
    By nickz5 in forum Shocks and Suspension
    Last Post: 09-22-2015, 08:01 PM
  2. Which 2016 Fork? 160mm Pike or 160mm Lyric for 650b
    By JNG in forum Shocks and Suspension
    Last Post: 09-07-2015, 11:36 AM
  3. Fox rc2 2011 (160mm) vans vs fox rc2 2014/2015 float (160mm)
    By jabba69 in forum Shocks and Suspension
    Last Post: 11-07-2014, 10:27 AM
  4. 2014 Pike 160mm Air Spring compatible with a 160mm Lyrik?
    By hafnz in forum Shocks and Suspension
    Last Post: 05-05-2014, 10:55 AM
  5. Downsizing rotors from 185mm/160mm to 160mm/140mm
    By xterrafreak in forum Brake Time
    Last Post: 02-26-2013, 12:03 PM
Members who have read this thread: 107
