First Ventana Kit Build- Mtbr.com
Results 1 to 23 of 23
    Reputation: Clockwork Bikes's Avatar
    I'll be starting my first Ventana full suspension build for myself soon and have a few questions. Walt, I saw some of your old blog post about this too.
    Will a 1.375" x .035" chromo tube be sufficient at the upper pivot point? The pivot is already mitered for 1.375" so I hope so.
    It looks like the lower pivot gussets provided by Ventana are unnecessary. Is there any reason I can't put the pivot tube in the middle of the seat tube? It looks like there will be clearance but I haven't done a full mock-up yet.
    There's not a lot of room for bronze fillets around the pivots. Would it be more prudent to TIG these?
    The lower pivot is supplied undersized. Are you drilling this to 15mm after welding?
    Thanks, Joel
    NOTHING WORKS LIKE CLOCKWORK
    www.clockworkbikes.com
    Reputation: Feldybikes's Avatar
    Quote Originally Posted by Clockwork Bikes View Post
    That tube size is probably sufficient. However, consider sleeving the tube at the pivot.
    It'll clear the seat tube at the bottom bracket no problem. You do, however, need to pay attention to the top of the seat tube. Using a straight tube, the seatstay bridge or tire can run into the seat tube. Depending on how much travel you're looking for (probably transitioning around 4"??) you'll need to bend and/or offset the seat tube forward.
    No, not a ton of space, but I've done it. If you have a tight miter, the fillet doesn't really do anything besides hold the pivot in place; it should be supported by the seat tube itself.
    I use an adjustable reamer.
    Moderator Moderator
    Reputation: Walt's Avatar
    I have mostly transitioned away from using the Ventana rear ends (building my last few frames with their hardware/rockers now) but I don't want to dig up all that old info, so, random thoughts and maybe useful answers.
    -As Feldy says, 1.375x.035 is fine. Sleeve the tube behind the pivot tower, though, and tie it all together (I just TIG this whole thing).
    -If you move the lower pivot forward by mounting it in the seat tube itself, remember a couple of things:
    1. You'll need to move the rocker pivot forward too, which will mean a bent or cut/welded seat tube. Mock everything up first, it can be quite a juggling act to keep the pivots where they need to go, the seatstay bridge/tire out of contact with the seat tube, and the insertion depth and angle of the upper bent portion of the seat tube compatible with the seatpost you want to use.
    2. Remember that the suspension behavior is going to be determined mostly by where that main pivot goes. If you don't want to get super geeky with Linkage, just line it up with the top of the chainring (whatever size you think you'll use) and you'll be at around 100% antisquat which is a nice neutral place to be. The stock Ventana pivot location will squat a decent amount under pedaling loads (can be desirable, or not).
    3. The angle between the seat tube and downtube will get really tight, which means you also need to very carefully check that your desired shock will fit (including at full compression). Fully mocking everything up before joining the pivot tower is highly recommended.
    -I would TIG everything if you have the ability/tools to do it that way. IMO not a great project to do with fillet if you have a choice. But it can be done.
    -I turn the main pivot tube out to 15mm before welding, then do a light cleanup (sometimes necessary, sometimes not) after welding/distortion has shrunk it a bit. If you leave it stock, you will have quite a bit of reaming to do - and you won't be able to use the swingarm as a fixture to hold the pivot in place while you tack it.
    -The alignment on the Ventana swingarm and seatstays is *atrocious*. You can work around this by just using the rear end itself to fixture the pivots before tacking/joining them. If you assume everything is square and install your pivot points as such, you will probably get an unpleasant surprise. This often means your wheel is not staying perfectly in plane with the frame through the stroke, but in practice it isn't noticeable.
    -Alignment/symmetry of the pivot tower (the steel piece that slips over the seat tube) is likewise often horrible. And it is machined quite sloppily such that it moves around on the seat tube. Make sure you install the seatstays/rockers as fixtures to ensure they are aligned/symmetrical. The yoke on the seatstays is pretty narrow and it will hit the side of the seat tube if you are not very careful here.
    Feel free to call me if you have other questions. It can be quite a can of worms when you first start doing these.
    -Walt
    Thanks, folks. I have an actual customer's bike to finish up and will then hit the Ventana kit--with more questions, I'm sure.
    Here we go. Decided to use a 1.38" x .065" ST and turn down some sections to .035" wall.
    Did you also bore out the middle to take a 31.6 seatpost? or are you going with a collar for 30.9? I like the externally butted tube you made! I experimented with some crude centerless grinding to make a 8/6/8 top tube with a really short center. Worked better than I expected.
    Looking forward to more of this build!
    Myth Cycles handbuilt bike frames
    Durango, CO
    http://www.mythcycles.com
    The ID is supposed to be 31.62mm but is a little under-sized, so a light ream should do it. Very convenient ID.
    Moderator Moderator
    That's bold and cool... but if the seat tube doesn't stay *perfectly* straight, it's going to be the reaming job from hell. Remember that you're only welding stuff to one side of the tube!
    Don't ask me how I know this...
    Then again you could just shim to 30.9 and solve it that way if it comes down to that.
    Man I wish I had a decent lathe.
    -Walt
    I know what you mean. I scored this 1.244" reamer on eBay which should take care of it.
    Quote Originally Posted by Walt View Post
    My lament every week. We live in a machine tool desert.
    Durango, CO
    Things are getting interesting.
    You should really put more effort into that shock mount. Have some pride, man!
    ;P
    Progress but my heart's not really in it because all I can think about is how I can make my own rear end. I've got some ideas I just need to flesh out in SolidWorks.
    No known cure
    Reputation: Vader's Avatar
    Does Sherwood sell the current gen rear end to builders? I ride the previous gen frame which was a custom build and also had the previous gen frame in steel by Curtlo. That frame was destroyed in a head on with a moto. I had Ventana build me a new front triangle using the old stays.
    Ripping trails and tipping ales
    Mar 2018
    That sounds fun. Want some help?
    I might have some time to contribute.
    Write me t@tgwms.com
    My carbon fiber full suspension frame build blog:
    https://carbonmtb.blogspot.com/
    All done but haven't ridden much since the trails are still pretty soggy here.
    Attached Thumbnails Attached Thumbnails First Ventana Kit Build-26968863867_7c65e3ac44_b.jpg
    Killer! That thing came out great! Is that powder coat? I like the fade.
    Durango, CO
    WIGGLER
    Reputation: todwil's Avatar
    Feb 2007
    Bike turned out nice Joel, as always!!
    PAYASO 36er.....Live the Circus
    MR. 36er TROLL
    I'm sorry what part of "BIGLY" didn't you understand?
    Noice!
    Moderator Moderator
    Joel, you don't mess around, even when your "heart isn't in it". I love that.
    -Walt
    will rant for food
    Lookin great.
    No known cure
    I love it.
  1. Xpost from Ventana Board - Ventana El Gordo Pics..
    By Ciclistagonzo in forum Fat bikes
    Last Post: 02-25-2014, 02:39 PM
  2. ISO Ventana El Rey or other Ventana 29er
    By rsmarg in forum Colorado - Front Range
    Last Post: 07-24-2012, 09:47 AM
  3. Replies: 43
    Last Post: 09-03-2011, 06:14 PM
  4. 2012 Ventana El Chucho (69'er) First Pics..
    By Ciclistagonzo in forum 27.5
    Last Post: 08-06-2011, 08:07 PM
  5. First Ventana Post
    By Fattirewilly in forum Ventana
    Last Post: 04-06-2009, 11:14 AM
Members who have read this thread: 15
