first frame started- Mtbr.com
Results 1 to 24 of 24
    Nov 2007
    first frame started
    After 10 years of dreaming I've finally started my own frame. It's a 650b, rim brake, all road bike (well, hopefully if it turns out ok). I've gotten the front triangle tacked except for where the seat tube covers the downtube, I welded that part.
    I don't have a jig, so I've been very careful with the miters and measured a lot. I need to research more on the order of welds to keep it straight. Hopefully done over the long weekend.
    https://imgur.com/a/0vi2PF6
    Nov 2008
    Cool. Looks like your off to a good start. I have been dreaming for awhile myself, happy to see you on your way.
    Looking forward to more pictures and details.
    Lucky neighbor of Maryland's Patapsco Valley State Park, 39.23,-76.76 Flickr
    Nov 2007
    first frame started-img_20190524_215101_340.jpgfirst frame started-img_20190524_215101_337.jpg
    I was able to get the chainstays attached with the dropouts. I fully welded the seat tube since it will be tricky to weld after I put on the chainstays. It stayed parallel with the BB shell, so that's a plus. I did realize one pretty big mistake that I can't undo, so hopefully it'll be allright.
    After I got the chainstays in the right spot and tacked, I checked to see if it'll clear the tire and crank I'm planning on using, and it will. The bb drop ended up being less than I designed (65mm) so I'm planning on welding the chainstays, then bending them up a tad (8mm each). Any feedback on this idea?
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    You will slacken the angles of both HT and ST if you do. Check the numbers, it may not change much and be within tolerance. Dropping the BB height may not be that important either and can be within tolerance.
    Depends on how you read the numbers.
    Sometimes you have to adjust as you go and compromise. I don't think you will end in disaster either way, but this is one of those learning experiences that you don't repeat on the next frame you build.
    Keep moving forward, this is what having a go is all about.
    Eric
    If I don't make an attempt, how will I know if it will work?
    Oct 2015
    Looking good! Hey what about Bending the chain stays like half as much as you are intending and then facing off some material from the bottom of the head tube so that the BB drops without as much effect on head and seat tube angles.
    Nov 2007
    I think if I didn't adjust the bb drop, it would steepen the angles from what I designed. I did bend them, but I agree it's probably within tolerance and wouldn't be too noticeable.
    Reputation: adarn's Avatar
    If your chainstays are just tacked it would definitely be the least work with the best results to pull them off and put them back on in the right spot. That one took me way too long to figure out.
    That said, looking good for your first frame. My first 10 were probably off more than that and I was so excited about them I didn't really care, just going through the motions you will learn a ton.
    Nov 2007
    Thanks, I've been preparing for this for 10 years, lots of small projects, frame modifications, around the house welding and repair. I just had to get over the fact that I don't have a jig, nor am I willing to invest in one yet.
    I didn't have the patience to cut out the tacks, and it was easy enough to bend the chainstays. The one thing that I really struggled with is getting a good miter on the seat stays, the gap was larger than I liked, but like Adam says I'm too excited to have it closer to being done and I'm hoping that since the seatstays are in compression it'll be ok.first frame started-20190527_202903.jpg
    I'm waiting on a fork (26" mtb, non-suspension corrected, going to relocate the brake bosses) and wheels before I move on. I have a paul racer brake for the rear, probably going to run a paul touring for the front. My goal is to get it ridable before cleaning it up and adding more braze ons in case it doesn't ride well.
    Frame Building Moderator
    Reputation: Walt's Avatar
    +1 to Adam's comments. Use your new experience to make the next one better, but for this one, get it built and enjoy. Congratulations!
    -Walt
    Nov 2007
    Update
    I had time to reflect over a 3 day tour and 4 days at the beach with the family and I decided to not settle for my mistakes with the seatstays. The miters weren't good, and they were pretty narrow at the tire, which also meant I wasn't going to be able to direct mount Paul Racer brakes.
    I'm going to get a saddle and handlebars on it tonight and ride it as a strider to see how it feels, then add on the brake bosses and get it built enough to ride for some test runs.
    Built as is the angles are close enough for what I designed. The seat angle is slightly steeper, which is ok with me.
    first frame started-20190610_221631.jpgfirst frame started-20190610_221623.jpgfirst frame started-20190610_221617.jpg
    Nov 2007
    I was able to get more parts hung on the bike. I used U bolt brake bosses turned down for the brake mounts, they'll only work with the Paul Racer, so I'm stuck with that brake forever I think.
    I did some strides on it up and down the street, and it seems ok, tracks straight, even no hands. I'm going to add the minimal braze ons soon so I can finish building it up enough for some test riding. Once I'm satisfied with that I'll finish the braze ons and see about paint. Any recommendations for how much test riding I should do on it?
    Looking pretty sweet and that brake looks nice on there. Id say finish building it up and as long as it functions as it should there isn't much need for test riding. Paint that beauty and get riding!
    Dec 2011
    I would observe the behaviour of the upper wishbone section of the seat stays under heavy braking. There is a bending moment taking place and the upper tube is on the small side OD wise and may flex excessively.
    Otherwise, looking good.
    Eric
    Nov 2007
    I think you're right. I got it built enough to take it around the block and though it's kind of dark out it looked like it was flexing a bit. I like the idea of a brace anyways, it'll create a little triangle that I can make a bag for to keep a tube and some tools in.first frame started-20190613_211400.jpg
    I don't have direct experience with wishbone stays, but that bridge piece looks a little stressed to me. Maybe not, seatstays don't see the most strain of all the tubes, but if you nail a bump while seated, that little bridge is going to take a lot of force.
    But at this point maybe just slam the rear brake a few times, and hit a pothole while seated, and if nothing bends then roll with it!
    Like others have said, the next frame you make will feel like a whole other project. Just making one is a huge step forward in your skillset.
    Myth Cycles handbuilt bike frames
    Durango, CO
    http://www.mythcycles.com
    Most Delicious
    Reputation: dr.welby's Avatar
    Have you folks seen any of Rob English's frames? His stays are quite a bit smaller.
    I second dr.welby on English framsets having smaller wishbone stay diameter. Ive always wondered about the flex and strength with that design...you'll have to let us know how it rides WVUcyclist!
    Most Delicious
    I would put some kind of cap or plug on that cross bar so you can't cheesegrater a nice curl of skin off of one of your calves. You have all sorts of options here, be creative!
    Doing things because you saw someone else do them is a good way to build stuff that breaks.
    Nov 2007
    I got the braze ons done, paint, and built up again. The biggest thing that I learned is that the propane torch sucks for brazing small parts. It got it hot enough, but heated too much area, and the silver flowed down the tube as well (too much silver). I am getting impatient, so I didn't sand it off, just painted it after cleaning off the flux.
    My standard for any new bike I get is to ride it 1000 miles before I really pass judgement on it, so check back in the fall for a report.
    I can't post pictures right now for some reason, will try later.
    Nov 2007
    Got in another ride today and found something interesting. At about 15mph with no hands it has a bounded shimmy. It didn't grow and wasn't uncontrollable, so I'm not too terribly worried.
    Side note: I keep getting upload failed when I try to put a picture up, any ideas?
    Dec 2011
    Quote Originally Posted by wvucyclist View Post
    What percentage of Silver rod did you use?
    55% for lugs/sleeves
    45% for Braze-ons
    34% for fillet
    55% is too runny if you use a large flame.
    Hope this helps.
    Eric
    Nov 2007
    Thanks, it was 56%, and it was a large flame. I switched to a small mapp/oxy torch for the rest of the braze ons and that did much better. I'll have to stock up for next time.
    Nov 2007
    Since upload isn't working for me currently:
    https://flic.kr/p/2giYinE
    https://flic.kr/p/2giY1j2
  1. Replies: 79
    Last Post: 04-06-2014, 06:54 AM
  2. Getting things started on my first build.
    By Danielrg_usa in forum Beginner's Corner
    Last Post: 08-01-2013, 04:02 PM
  3. Replies: 2
    Last Post: 07-05-2013, 01:30 PM
  4. Who started MTBR and when did it get started?
    By spencer the kalmyk in forum Beginner's Corner
    Last Post: 11-16-2007, 12:12 PM
  5. First post, first build, first SS, first ride
    By skogorbet in forum Singlespeed
    Last Post: 12-01-2005, 10:07 AM
