An English language mechanical question- Mtbr.com
Results 1 to 14 of 14
    No Fear
    Reputation: Iranian-Mechanic's Avatar
    I was wrintting a text about something that in the middle i wondered what a specific thing is called in English
    The split between two halves & two sections of the seat post clamp ans the cut in the frame its self that ensures the seat post entering diameter to alter a little bit and grab the post
    In general any kind of narrow cut like this in an object or mechanical part what do you call it in English ??
    Thanx a lot
    A rider/online bike shop owner/Mechanic From Iran
    Most would say a split, or maybe a slit.
    No Fear
    Quote Originally Posted by Cord View Post
    Thanx
    how about ( Gap ) ?
    Reputation: WHALENARD's Avatar
    Feb 2010
    Gap
    Slit
    Cut
    Cut out
    Relief
    Break
    Partition
    Hole
    Groove
    Split
    And probably a dozen other acceptable words.
    My understanding is your supposed to align those two gaps 180° from each other.
    It is no measure of health to be well adjusted to a profoundly sick society.
    Quote Originally Posted by Iranian-Mechanic View Post
    Thanx
    how about ( Gap ) ?
    It is technically a gap, but that word wouldn’t usually be used to describe what you have pictured. A gap is more commonly (but not always!) used to describe when 2 things don’t fit together properly.
    To put it into context, it would be more common to say. “The seatpost collar has a slit/split/cut-out.” However, English is a funny language, and there are lots of other words that would also work.
    No Fear
    Hmmm got it man thanx a lot
    how about the gap between the stem cap and its main body ? Can we call that a gap or is it a slit too ?
    No Fear
    Quote Originally Posted by WHALENARD View Post
    Gap
    Thanks a lot for the words
    About the alignment of those slits are you sure ?
    g=9.764m/s2
    Reputation: Undescended's Avatar
    Apr 2018
    That is a gap where as upon installing, the top and bottom gap should be equal. Think of a slit as a cut in a solid like to cut a slit in your bike wrap to work around a cable.
    On my bikes the clamp gap is inline withe the seatpost slit.
    Feb 2010
    No, I'm not sure. There was a thread on this very topic a ways back and some frame manufacturers do indeed state to run them 180° from each other while others state to align them. I typically align them.
    Feb 2010
    Gap would typically be used over slit in this context.
    No Fear
    Quote Originally Posted by Heist30 View Post
    Thank you very much
    its a Specialized Demo 2011
    Dec 2012
    The cut in a round tube like a seat tube or seat post clamp is called a "slot" or "slit". The space between the clamping surfaces of a two piece clamp would be a "gap".
    No Fear
    Quote Originally Posted by DSaul View Post
    saddlemeat
    Reputation: bsieb's Avatar
    Aug 2003
    Yep... slot, gap.
    I ride with the best dogs.
  1. New 29er (Mechanical Brake Question)
    By ziconater in forum 29er Bikes
    Last Post: 06-20-2013, 04:14 PM
  2. Mukluk Mechanical Question
    By Davesnhere in forum Fat bikes
    Last Post: 12-05-2012, 04:07 AM
  3. question about a few mechanical MTB stuff
    By willc86 in forum General Discussion
    Last Post: 08-11-2011, 01:08 AM
  4. Mechanical Brake rub question
    By TheDoc46 in forum Beginner's Corner
    Last Post: 06-11-2011, 07:40 PM
  5. Hayes Mechanical Vs. Avid Mechanical
    By Turt99 in forum Brake Time
    Last Post: 10-27-2005, 08:11 PM
