Custom fork not as excepted- Mtbr.com
Results 1 to 17 of 17
    Aug 2019
    i have a new frame and fork, we discuss on the fork a-c crown, deciding it to be 430, i now check the fork and he is 420, is this 1cm is a mistake that can happen? is the job of making the fork is hard to be precise with?
    im asking that because now i see that my top tube is not horizontal, the little bulb shows that the bike lean more down to the front, which will make me lean more down to the front, i should say that the bulb is not really out of balance but there is a slight drop, do you think its something i should consider change or this is not critical?
    thanks in advance.
    Wanna ride bikes?
    Oct 2013
    There are a varieties of mistakes people can make when measuring A-C. Post a picture of what you are measuring.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Aug 2019
    Attached Thumbnails Attached Thumbnails Custom fork not as excepted-img-5695.jpg
    Shartacular Spectacular
    Reputation: Shartist's Avatar
    Aug 2018
    I think the 1 cm offset might be a measuring error caused by those fingernails.
    18 SC Bronson C
    Grip2, Reserve 27's, i9, Float X2
    18' SC V10
    Fox 40 w/Avy air/coil, WAO: The Outlier, i9, Avy Woodie
    Aug 2019
    Quote Originally Posted by Shartist View Post
    haha i like them..
    Reputation: Spindelatron's Avatar
    Quote Originally Posted by Guy22 View Post
    haha i like them..
    for breaking down a cigar for a blunt or ???
    Aug 2019
    Quote Originally Posted by Spindelatron View Post
    nah, just easier to peel oranges with that, and i love the overall look.
    Reputation: Eric Malcolm's Avatar
    Dec 2011
    One option is that the builder has not made a bespoke fork at all and supplied a generic version.
    Option 2 is that he made it wrong.
    You should be able to ask for what you paid for and return the incorrect fork.
    Have you discussed this with the builder?
    No good going to the forum first.
    Eric
    If I don't make an attempt, how will I know if it will work?
    pvd
    pvd is offline
    Reputation: pvd's Avatar
    In the photos, it looks like you aren't measuring the fork correctly.
    Aug 2019
    Quote Originally Posted by Eric Malcolm View Post
    Eric
    there was already a problem in the fork, that he fixed.
    now there is that one, i will check with him.
    do you think i measure the fork correct?
    Aug 2019
    why? middle of axle to top of crown.
    Aug 2019
    Quote Originally Posted by pvd View Post
    why? middle of axle to top of the crown..
    Jan 2009
    It helps if you PUT PANTS ON.
    Aug 2018
    And by or??? I think hes asking if those are five pronged excavators of blow mountain.
    18 SC Bronson C
    18' SC V10
    Aug 2019
    Quote Originally Posted by mack_turtle View Post
    give me a break..this is how im hanging around in my area, keep your head open, still love you though
    Most Delicious
    Reputation: dr.welby's Avatar
    Since no one will answer your question:
    Axle to crown is measured parallel to the steerer tube, so you have the wrong piece of the triangle.
    But let's say the fork is 430 A-C with 50mm offset. Using the Pythagorean theory, we can calculate what the distance you are measuring should be:
    sqrt(430*430 + 50*50) = 433
    So even measuring the wrong number, the distance should be close to 430, and it is definitely not!
    Aug 2019
    Quote Originally Posted by dr.welby View Post
    thank you sir
  1. Anyone get any custom/ semi custom jerseys from Voler?
    By wrecognize in forum Apparel and Protection
    Last Post: 09-23-2015, 03:11 PM
  2. Alivio BR-M4050 tad weaker than excepted?
    By grumpy old biker in forum Brake Time
    Last Post: 07-25-2015, 03:48 AM
  3. Challenge excepted - Mongoose Beast.
    By xtreamedrtbker in forum Fat bikes
    Last Post: 10-03-2013, 08:45 PM
  4. Help! Custom shop not talking and me not riding
    By cleo in forum Custom Builders & Other Manufacturers
    Last Post: 08-22-2011, 07:57 PM
Members who have read this thread: 114
