Can this be repaired?- Mtbr.com
Results 1 to 11 of 11
    Hi,
    I have a custom-built steel tandem with a damaged dropout (see picture). I think the chain got caught between the cassette and wheel.
    Is it possible to repair this bike? Does anyone have recommendations for Washington DC area frame builders?
    Thanks.
    Brad
    Frame Building Moderator
    Reputation: Walt's Avatar
    Yes
    That should be an easy fix for any framebuilder with some fillet brazing experience. Couple hundred bucks, at most (not counting paint, if you want to repaint the bike, that could get expensive).
    I don't know anyone in the DC area, though. Palermo is in Maryland, somewhere, I think - is that close enough?
    As an aside, I am suprised that the joint would fail that way. Looks like the brass did not bond well to the dropout.
    -Walt
    Bike Freak
    Reputation: jgerhardt's Avatar
    When I took the class at UBI it was mentioned that they do not use those type of dropouts for fillet brazing as it is not ideal for that type of connection. I am pretty sure it also had to do with the fact we were all a bunch of noobs who had little if any experience brazing.
    Also, on a side note the chain and seat stay look pretty darn close together. Like they almost do not have a full fillet around each one. This might be typical however for this type of dropout.
    My bikes [Fe][C]ycles
    Palermo Bicycles
    he would do a great job on this
    Randomhead
    the bottom half of the joint looks dirty, it makes sense that this joint was failing before the incident
    Thanks for the advice.
    I'll contact Palermo Bicycles in Baltimore and see what it will take to repair.
    Brad
    Squelch the weasel.
    Reputation: JaquesN's Avatar
    fillet separation
    This type of failure is something I'm worried about as a framebuilder. What would cause a fillet to peel back from the material it's attached to? Bad surface prep?
    I have tested dozens of my own joints and only seen this type of failure once. I don't know what I did differently that one time, so it has always bothered me.
    Feb 2006
    Have you contacted the framebuilder? It's a custom built frame so it seems that the builder should stand behind the work and repair it.
    Apr 2005
    Looks like the rust worms were starting to have a party in that there chainstay.
    I have seen a lot worse damage from a chain getting sucked into the spokes.
    The prep time will likely cost more than the actual brazing, if you have the time and inclination, you could offer to strip and lightly sand the stays (the dropout looks bent, and may be trash), but let the framebuilder make that call after reviewing pics.
    Quote Originally Posted by jgerhardt View Post
    I would agree with UBI but only concerning the breezer version of this drop-out which I just call a "hooded" dropout or a wright style dropout.
    Paragon has some great ones that have a much wider hood. It gives a lot more surface area to braze too and they work pretty well. I had the same issue once with brazing and a Breezer. There was very little area below the CS and it started to crack there (took 50k miles but all the same)
    I'm just messing with you
    Reputation: wv_bob's Avatar
    FWIW the Ritchey version of a hooded dropout
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
  1. Can this be repaired ?
    By jpeters in forum Frame Building
    Last Post: 07-05-2011, 03:04 PM
  2. Return to LBS or have repaired?
    By hotrozz in forum General Discussion
    Last Post: 12-08-2010, 04:20 PM
  3. RIPv1.0 repaired
    By Johnny D in forum Niner Bikes
    Last Post: 11-14-2010, 04:17 PM
  4. If You Need Your 36 Serviced/Repaired...
    By dirtpunk7 in forum All Mountain
    Last Post: 01-21-2009, 09:07 AM
  5. Can this be repaired?
    By AK47 in forum Wheels and Tires
    Last Post: 08-08-2008, 01:41 PM
