Can this be repaired ?- Mtbr.com
Results 1 to 5 of 5
    Reputation: jpeters's Avatar
    I just want to know can this be repaired? I started a thread and the pics are here.
    http://forums.mtbr.com/showthread.ph...55#post8204155
    Frame Building Moderator
    Reputation: Walt's Avatar
    Toast!
    Not fixable. You need a new frame.
    IF that is the original shock and rear end/rockers, that's a serious design problem. Rear end hitting the seat tube on hard hits is bad, bad, bad.
    -Walt
    Yeah its all stock I did not change anything its under warranty so I hope I get a new one. I was just wondering if it was possible to get someone to repair the crack if I don't need to send it back. Why is it not possible to repair it?
    Spanish rider
    Reputation: Pableras's Avatar
    [QUOTE=jpeters;8210213 Why is it not possible to repair it?[/QUOTE]
    Because it's (badly) bent.
    If you try to bend it back to the original shape you'll weaken the frame more than it is now, probably cracking it, so this doesn't seem as a good idea.
    You could rebuild the bent area welding new tubes, but you'll end up with a messy and unsafe result.
    Note that other areas of the frame may be affected (shock mount, rocker arm....).
    It's simply not reapairable
    A pessimist is an experienced optimist
    Oh ok Thanks !!! I know nothing about frame building just wondering Thanks
  1. Return to LBS or have repaired?
    By hotrozz in forum General Discussion
    Last Post: 12-08-2010, 04:20 PM
  2. RIPv1.0 repaired
    By Johnny D in forum Niner Bikes
    Last Post: 11-14-2010, 04:17 PM
  3. If You Need Your 36 Serviced/Repaired...
    By dirtpunk7 in forum All Mountain
    Last Post: 01-21-2009, 09:07 AM
  4. Can this be repaired?
    By AK47 in forum Wheels and Tires
    Last Post: 08-08-2008, 01:41 PM
  5. Replies: 5
    Last Post: 10-04-2007, 04:09 PM
