Results 1 to 6 of 6
    Building my fatbike
    Hello, i'm french rider from britanny.
    There were 6 months, i decided to try buildind my own frame.
    i started to draw it with Rattlecad.
    February, Colombus tubes arrived at Home.
    March to july were OFF: too much work... But it permit to finalize my project: geometry,internal routing, 44mm head tube, carbon fork...
    07.15.2015: building was beginning:
    Wheelbase tubing work:
    Day 2:
    Day 3:
    First building:
    Details:
    Frame: Colombus Zona, weight 2.2kgs
    Fork: chinese Carbon : 620g
    Wheelset: Origin 8 60mm; 170mm rear, 135 front.
    Hope tech M4 brakes.
    Reverb stealth post in waiting
    Total weight: 13.2kgs
    Not really finished: polished and paint are in stand by.
    I'm happy like a young kid at Cristmas!!!
    First bike named: Ange (angel in english) ,godfather name who helped me a lot.thx
    Moderator Moderator
    Reputation: Walt's Avatar
    I am not a fillet brazing expert but I'm pretty sure that is not enough bronze to be safe to ride.
    -Walt
    Nemophilist
    Reputation: TrailMaker's Avatar
    I concur;
    I'm not a brazer either, but I feel the main tube fillets - at the least - need to be more substantial, unless the bike is only lightly ridden. Easy to fix.
    Congrats on your effort!!!
    Most people ply the Well Trodden Path. A few seek a different way, and leave a Trail behind.
    - John Hajny, a.k.a. TrailMaker
    Feb 2013
    I agree with the above 2 replies, Does not look like enough LFB... Also looks like there may be too much heat on those joints.
    thx guys. I heard your advice:
    Heat for seat tube: probably!!! hope it doesn't broke.
    Reputation: Feldybikes's Avatar
    I can't tell from those last pictures you posted (very fuzzy), but you might still be a bit small on the fillets. If that's the case, adding more may or may not be a good thing (heating 3x).
    In general, it's relatively easy to make a fillet joint that appears to be strong enough. E.g. with a very small fillet you can in some/many cases put a joint in a vise and bend the tube while the joint will hold, while the same joint will fail in fatigue if you ride it awhile -- keep an eye out for cracks! Though I personally have no experience with this
    Really like your SS attachment, BTW.
  1. Replies: 9
    Last Post: 12-03-2014, 01:37 PM
  2. Building a fatbike groomer... What width?
    By Coloradogoose in forum Fat bikes
    Last Post: 01-13-2014, 06:22 PM
  3. Building fatbike forks.
    By Mattias_Hellöre in forum Fat bikes
    Last Post: 03-14-2013, 12:18 AM
  4. New Fatbike Build (LBS or experienced FatBike shop)
    By synthesis in forum Fat bikes
    Last Post: 02-23-2013, 03:56 AM
  5. Replies: 2
    Last Post: 06-06-2011, 05:12 AM
