bent seat tube dimension suggestions- Mtbr.com
Results 1 to 8 of 8
    Ipso Facto
    Reputation: bikecycology's Avatar
    I am going to have some tubes bent. They will be 24" long overall. I am doing two at a 6.75" CLR and two at a 9" CLR. I'm hoping to see what people are doing are would suggest for the length of the straight section before the bend starts. And since we are in to this discussion, what is a good degree of bend to go with? Thoughts?
    Thanks, Wil
    Frame Building Moderator
    Reputation: Walt's Avatar
    Before you go do that, there are already (assuming you want to fit a dropper) 3 options available commercially:
    -Vari-Wall
    -PVD (still available I believe)
    -Waltworks
    -Walt
    pvd
    pvd is offline
    Reputation: pvd's Avatar
    I may do another run in the future. Not many people were interested the last time which was discouraging. Tooling is all paid for now and that was the tough nut.
    For mountain bikes and folks under 6' tall, you need to get the bend as low as possible in the frame. Thus, I use a 30 degree bend at 3.0" CLR.
    PVD Blackbird Seat Tube OEM Order | Peter Verdone Designs
    pvd
    pvd is offline
    The info on this post is good if you are talking about bent seat tubes.
    The right way to build and spec bent seat tubes | Peter Verdone Designs
    Dec 2012
    Framebuilder Supply has "29er" bent seat tubes, externally butted, for 27.2 internal diameter.
    https://framebuildersupply.com/colle...1-2-length-550
    pvd
    pvd is offline
    We don't build with 27.2mm tubes anymore.
    mbtr member
    Reputation: scottzg's Avatar
    Quote Originally Posted by pvd View Post
    That's really disappointing to hear.
    "Things that are complex are not useful, Things that are useful are simple."
    Mikhail Kalashnikov
    Quote Originally Posted by scottzg View Post
    That's odd, too. I've sold probably 50 of mine (and used another 25 myself).
    Might be the sales model. A lot of people don't like the preorder/crowdfunded thing. I just generally have a few hundred of whatever I want made (ie fork blades, seat tubes, etc) and figure if nobody wants to buy them that's fine. I'll use them eventually.
    -Walt
  1. Replies: 24
    Last Post: 03-13-2015, 04:25 AM
  2. Replies: 12
    Last Post: 01-07-2015, 09:53 AM
  3. Curved, bent, offset, non-traditional seat tube
    By Varaxis in forum Frame Building
    Last Post: 01-03-2014, 08:44 PM
  4. Seat tube, top tube, head tube deal
    By calstar in forum Frame Building
    Last Post: 08-29-2013, 10:12 AM
  5. Bent seat tube in a Diamondback step through frame.
    By zerodish in forum Frame Building
    Last Post: 02-20-2013, 11:56 AM
