bearing renoval 101- Mtbr.com
    Apr 2013
    bearing renoval 101
    I hate those mtb bearings, always super hard to remove with all those curvy surfaces. How am I supposed to remove that bearing ? A press/extractor won't work...is a blind hole puller the only option here ?
    Attached Thumbnails Attached Thumbnails bearing renoval 101-44e15d5c-ffd9-4dd8-99ec-a8ad32bdee87.jpg
    EAT MORE GRIME
    Reputation: 127.0.0.1's Avatar
    Nov 2013
    canned air duster, and freeze it, helps somewhat....with a knock from a matching socket
    harbor freight is your blind puller resource tho, and it the better method
    "Put your seatbelt back on or get out and sit in the middle of that circle of death." - Johnny Scoot
    Apr 2013
    it's way too big for my sockets, OD of 30mm
    Dip the hole thing in some very hot water, then like 127 says, canned air duster just on the bearing, try to get a temperature differential between frame and bearing. It should tap out super easy then. Frame looks aluminium?? If so it might come out just via heating. As the aluminium will expand more than the steel of the bearing. Ideally a socket (or something else round) and spread the load across the entire inner race. Not ideal, but you can only piss with the cock you got.
  1. bearing and needle bearing source recommendation
    By rudy1337 in forum Shocks and Suspension
    Last Post: 10-04-2013, 08:14 AM
  2. Replies: 0
    Last Post: 03-05-2013, 05:14 PM
  3. BB30 bearing fits on PF30 bearing cups?
    By Tjay in forum Shimano
    Last Post: 07-24-2012, 12:28 PM
  4. BB30 bearing fits on PF30 bearing cups?
    By Tjay in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-24-2012, 12:27 PM
  5. 101 Questions from a Newbie (Well, not quite 101)
    By Asbury in forum Endurance XC Racing
    Last Post: 04-09-2007, 10:57 AM
