alignment of thru axle fork- Mtbr.com
Results 1 to 10 of 10
    Aug 2019
    ive got a frame lately and seems that the dropouts are not in balance, ive checked the dish of the wheel and its good, seems like one dropout is 1-2mm lower then the other, causing wheel tilt more to the other side of the fork.
    ive spoke with park tool about their ffg-2 tool and its just apply to the qr dropouts.
    something i can do about that?
    thank you.
    pvd
    pvd is offline
    Reputation: pvd's Avatar
    Gotta build them right or they are dust.
    Aug 2019
    Quote Originally Posted by pvd View Post
    Fuc*!
    RAKC
    Reputation: tigris99's Avatar
    You dont have them dished correctly or your using some cheap chinese garbage forks.
    Sent from my SM-N975U using Tapatalk
    Aug 2019
    Quote Originally Posted by tigris99 View Post
    checked the dish, the fork was made by the frame builder.
    seems like one leg of the fork bent more to the side, causing the upper part to rotate in, at least i can see it in my eyes.
    if the dropouts wasnt alignment so the Thru axle wouldnt be the thread in no?
    Pictures?
    Aug 2019
    Quote Originally Posted by Cord View Post
    Pictures?
    there it is
    Attached Thumbnails Attached Thumbnails alignment of thru axle fork-dsc00029.jpg
    If youíre definite itís not the wheel, then thatís not good! No easy fix there Iím afraid.
    Aug 2019
    it looks like the tyre does not seat right, but the mechanic check the dish and tell me everything is ok with the whee, i dismount the tyre couple of times and mount them again trying to make him sit straight as possible, can the rim itself be bent?, they are new!
    If you still arenít 100% itís the wheel. Then just flip the wheel 180į and see where the error is. If the error switches side, itís the wheel, if it stats on same side, itís the fork.
  1. Replies: 8
    Last Post: 02-15-2020, 02:32 PM
  2. rear thru axle alignment issue
    By BCsaltchucker in forum Frame Building
    Last Post: 09-15-2016, 07:04 AM
  3. Need help. 9mm thru axle to a 15mm thru axle.
    By specialized11 in forum 29er Bikes
    Last Post: 07-05-2013, 03:33 PM
  4. Replies: 4
    Last Post: 06-19-2012, 04:52 PM
  5. Replies: 0
    Last Post: 09-02-2008, 06:57 AM
Members who have read this thread: 44
