7005 Frame - Crack Welding Repair- Mtbr.com
Results 1 to 9 of 9
    May 2010
    I have been browsing the internet for a few days since I cracked my 7005 frame at a gusset weld, which then propagated down through ~1/2 the downtube all within a week or so, this frame is known to crack at this location.
    7005 Frame - Crack Welding Repair-20180927_222802.jpg7005 Frame - Crack Welding Repair-20180927_222817-1-.jpg
    The bike is great, I want to keep it, I ride it hard.
    I am connected with some master AL TIG welders who work on auto racing parts and mountain bike frames. They have both told me that they can weld my 7005 frame no problem and it will be just as strong, it is an advantage of 7005.
    The plan is as follows:
    1) Remove paint and prep weld area appropriately
    2) Weld crack + area around crack, will be a multipass weld most likely
    3) Artifical aging of frame for 6 hours at 200 deg F, then 4 hours at 320 deg F
    4) Spray paint over weld
    I appreciate any and all comments from the frame building community, if anyone has had success stories with welding 7005, please let me know! Also, any failure stories with 7005 are much appreciated as well!
    Dec 2012
    There's an area of the crack under the current weld that won't be repaired. Likely that crack will just continue to propogate -- through or around the weld repair.
    May 2010
    Quote Originally Posted by briderdt View Post
    What if that weld was ground down and then gusset to tube was rewelded? Or the gusset removed, the frame welded, and then the gusset replaced.
    Also - what makes you say that there is an area of the crack under the current weld? It seems like crack has gone along the edge of the weld and then down into the tube itself.
    Reputation: life behind bars's Avatar
    May 2014
    Try it, you'll only be out the repair costs. That said, I think you'll only delay the inevitable next failure.
    I ncredibly
    M yopic
    B ackstabbing
    A ssholes
    May 2010
    Why is that? That seems to be the general consensus amongst people, but I don't see why. Is it because aluminum is designed for so many stress cycles? And if I have a crack somewhere that is fixed another stressed area will just crack as well?
    This frame fails in this area relatively commonly, so my thought is that melting (welding) that area will relieve all the stresses and form a stronger area that before with new multi pass welds on it.
    May 2014
    Quote Originally Posted by swensonator View Post
    Using that logic the original weld would have eliminated all the stress, no? The leverage of an extended seat post is creating the cracks in the HAZ of the gusset weld.
    I ncredibly
    M yopic
    B ackstabbing
    A ssholes
    May 2010
    With that logic yes, all of the stresses that I am inducing through riding, any micro-fractures will be melted and reformed as a solid again, right?
    May 2014
    And rinse and repeat.
    I ncredibly
    M yopic
    B ackstabbing
    A ssholes
    May 2010
    Quote Originally Posted by life behind bars View Post
    As in I'll just end up in the same place as I am now? Just down the line, and not necessarily soon? That is just the nature of dealing with aluminum?
  1. Welding a Crack in Aluminum Frame
    By 50cents in forum Arizona
    Last Post: 12-19-2014, 10:52 PM
  2. Welding a Seat Post Crack
    By Mantramsagro in forum General Discussion
    Last Post: 07-22-2014, 04:33 PM
  3. Crack on welding seam or paint cranking?
    By WarPigs in forum Bike and Frame discussion
    Last Post: 10-28-2012, 08:28 PM
  4. Possible Welding flaw on my frame = welding "hole" = Crack?
    By Nick_M2R in forum Downhill - Freeride
    Last Post: 02-11-2011, 07:29 AM
  5. Frame Question about 7005 Aluminum Advanced frame
    By Jatt5 in forum Bike and Frame discussion
    Last Post: 07-27-2008, 08:50 PM
