2Souls Cycles X-12 dropouts- Mtbr.com
Results 1 to 8 of 8
    J_K
    J_K is offline
    Anyone using 2Souls Cycles X-12 dropouts? How do like them?
    I'm thinking of using 142x12 through axle dropouts on my 29er frame and those are one option. Any other similarly designed 142x12 dropout available?
    Rear - all - www.paragonmachineworks.com
    Paragon do make some. Not the same, but similar
    Guillaume
    Cycles Golem
    Reputation: Clockwork Bikes's Avatar
    They're pretty slick and come with the Syntace axle. I will try the Paragons next time.
    -Joel
    26" MTB - a set on Flickr
    NOTHING WORKS LIKE CLOCKWORK
    www.clockworkbikes.com
    Frame Building Moderator
    Reputation: Walt's Avatar
    Why?
    What benefit do you think you'll get on a hardtail from a rear through axle? I'm not saying it's wrong/bad, but if IMO there's not really any point. Makes way more sense for FS bikes where you can gain a little stiffness (maybe) but even there I'm dubious that they're detectable in a blind test.
    -Walt
    No other reason than I like the clean integrated look and the der. hanger is beefy and replaceable.
    -Joel
    J_K
    J_K is offline
    Quote Originally Posted by Clockwork Bikes View Post
    -Joel
    Thanks for the info Joel.
    Main reason why I would like to use these is clean look and beefy looking hanger.
    Avalability in Europe is also better than Paragon, they're cheaper also since they come with the axle.
    Compatibility would be another reason to use them. If your fs bikes have 12x142 this would make swapping wheels around a lot easier.
    Good point
    As someone whose personal bikes generally aren't very cross-compatible (ie long-travel DH, XC, CX) I had not thought of that point. Yes, that's definitely a good reason to do it if you swap wheels around a lot.
    -W
    Quote Originally Posted by shirk View Post
