29+ drop bar- Mtbr.com
Results 1 to 11 of 11
Thread: 29+ drop bar
    Reputation: ciquta's Avatar
    Nov 2015
    29+ drop bar
    Rookie here, I'm about to pull the trigger on my first build.
    It's gonna be a Ti frame for bikepacking purposes.
    Drop bar specific, geometry stolen from Salsa Fargo/Deadwood with a deeper BBdrop.
    I plan to use 29x2.6" Nobby nic but I made clarance for 29+ on 35mm rim.
    Comments are welcome
    Ipso Facto
    Reputation: bikecycology's Avatar
    Quote Originally Posted by ciquta View Post
    Hope the best for you. I assume you have welding experience? Do you have experience with Titanium? Seems like a jump into the deep in to me, but I guess that that is based on my comfort level. I have built one frame (steel) and it was an incredible experience. I liked the problem solving aspect of the process. I have two more frames in the works. Good luck, nonetheless. I look forward to watching your progress.
    Wil
    Nov 2015
    no it's not me doing the welding, I can barely lace my shoes
    it's still an experience but there are a lot of decisions to be taken
    Reputation: life behind bars's Avatar
    May 2014
    Your frame builder of choice should be walking you through this.
    "These things are very fancy commuter bikes or really bad dirt bikes, but they are not mountain bikes." - J. Mac
    Nov 2015
    the biggest doubt is about chain plates vs tubing in the rear... the plates gives more clearance but I'm afraid they are less reliable
    pvd
    pvd is online now
    Reputation: pvd's Avatar
    1. Titanium is a lousy material to experiment geometries on.
    2. Drop bars with huge tires isn't a great choice.
    3. Don't copy geometries. Learn about them and make decisions.
    Here's where I went:
    Hybrids are back! | Peter Verdone Designs
    Nov 2015
    I'm not really copying, I have experience on a few bikes and I have learnt my needs.
    Why you think titanium is a lousy material for such a bike?
    pvd
    pvd is online now
    Sounds like you're a better designer than I am.
    With regard to material, simply, if you are doing any serious designing of a frame, the first iteration will be far from right. It may have problems or there may be room for improvement. Instead of 1 ti bike that isn't that much better than anything else but very expensive, plan on 2 cheap steel bikes. It's worth it.
    Nov 2015
    I don't mind steel, I just found out Titanium is not so much more expensive than steel when you go custom.
    And I have a 36+ inseam with relatively short torso, so going custom is not just a whim.
    Based on you experience, what do you think about the tubing/plates matter?
    pvd
    pvd is online now
    Yes. Tube choices are very important. Lots of bikes are destroyed by poor tube choice.
    Moderator Moderator
    Reputation: Walt's Avatar
    Ah, XACD strikes again. Or do they have a new name now?
    Chinese ti = you get what you pay for. Good luck.
    -Walt
  1. How NOT to take a drop
    By mblittle in forum Yeti
    Last Post: 03-10-2015, 03:54 AM
  2. Replies: 4
    Last Post: 12-10-2014, 03:24 PM
  3. To drop or not to drop...
    By kragu in forum 29er Components
    Last Post: 11-14-2012, 09:05 AM
  4. Drop out help!
    By scribble79 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-03-2012, 02:56 PM
  5. Chain drop drop off and misalignment a norm?
    By boardrider02 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-03-2012, 01:20 PM
