2020 vs 7005 alloys?- Mtbr.com
Results 1 to 10 of 10
    Anyone have an expertise on the differences between these alloys?
    Lots of info on 6061 vs 7005, but not so much on other alloys, though I know 6069 is also common on some higher end alu frames.
    I'm looking at the new Orbea Oiz alloy frame, and most of my other bikes are 7005 or Scandium alloys. Just fascinated by the differences in alloy properties and wondering if the fatigue strength of 2020 alloy is comparable to 7005.
    May 2005
    https://www.sciencedirect.com/scienc...25541684900788
    Also,
    page 178, regarding GTAW of 2020:
    http://files.aws.org/wj/supplement/WJ_1991_07_s173.pdf
    ...not much about fatigue in that last article, but good info about strength of weld regions following heat-treatment.
    Is it defo 2020? I've used it but its rare, as i recall it is a forged offspring of 2024 but with an added Lithium content to make it less dense.
    UTS of all 2XXX series is only slightly lower than 7XXX, however i understand 2 series to be more prone to cracking after weld, but i ain't a welder, so thats not guranteed correct!
    i missed Vega Singles post, looks far more official than my head scratch! read that instead of listening to me!
    > Orbea Oiz Hydro High Polished 2020 Alloy link Boost PF Taper UFO2 I-Line
    Is the description of the frame.
    Reputation: Tim-ti's Avatar
    Could 2020 just be the model year? Either way, if you're not planning on welding things to your frame the particular grade of aluminum in a frame is not terribly important to a bike buying decision.
    "...DirtBaggies may also be the best baggy mountain bike shorts on the market." Velonews - Click to check out other reviews.
    Iím with Tim. Itís model year!
    Reputation: octanejake's Avatar
    Oct 2010
    Another reference to the tubes being 2020 aluminum:
    The new alloy Oiz H frameset uses a butted & hydroformed 2020 aluminum alloy tubeset that Orbea first welds, then smooths & polishes by hand.
    https://bikerumor.com/2019/07/18/orb...mountain-bike/
    Sorry, I have nothing useful to add.
    lets wait a year and see what its called?
    2020 is the ALU alloy. Not the model year.
  1. 2020 Hightower 2 vs 2020 Tallboy 4
    By Doug in forum Santa Cruz
    Last Post: 07-07-2020, 10:47 AM
  2. 7005 vs 6069 vs 6061
    By retrobeast in forum 29er Bikes
    Last Post: 04-02-2014, 05:14 PM
  3. Information about Aluminium Alloys
    By Fielding in forum Downhill - Freeride
    Last Post: 02-03-2012, 06:36 PM
  4. tube bending with fusible alloys
    By mchimonas in forum Frame Building
    Last Post: 01-11-2012, 10:58 AM
  5. Niner steel frames - full 853 or combo of alloys?
    By dlcrow in forum Niner Bikes
    Last Post: 06-24-2011, 02:27 PM
