2 bikes - effects of relative fork/headtube lengths- Mtbr.com
    May 2017
    Given the bikes in the image below have practically identical geometries other than fork/head tube lengths what differences in their rides would you expect?
    I can't help but think they should ride differently but can't see why/how.
    Reputation: Velobike's Avatar
    I would suspect the bikes would feel very much the same with identical builds and materials. The variation in the offset makes only a slight difference to the trail, and could be nullified by using a slightly fatter/thinner tyre.
    You'd have to be as sensitive as the Princess and the Pea to notice a 1mm difference in wheelbase.
    All else is equal.
    I would expect there may be a noticeable difference in feel though because the longer front fork would have more fore and aft flex.
    Latitude: 5736' Highlands, Scotland
    Moderator Moderator
    Reputation: Walt's Avatar
    A little more fork flex (could be good, could be bad). Otherwise no noticeable difference.
    -Walt
    May 2017
    More flex would be good so that works for me. Cheers both, was hoping that would be the case.
  1. Replies: 8
    Last Post: 10-22-2017, 07:27 AM
  2. Replies: 2
    Last Post: 09-19-2012, 08:51 AM
  3. Relative spoke tension on new wheel build
    By steveccnv in forum Wheels and Tires
    Last Post: 07-01-2012, 01:05 PM
  4. Opinions on RockShox SID (relative to Fox Float & TALAS)
    By tetonrider2 in forum Shocks and Suspension
    Last Post: 11-30-2011, 12:58 PM
