Will 12mm axle fit on Surly horizontal dropouts?- Mtbr.com
Results 1 to 5 of 5
    Reputation: duggus's Avatar
    Sorry if this is a stupid question. I'm building up a moonlander, but this will be my first build dealing with horizontal dropouts. Does anyone know if a Hope Pro2 rear hub with the 12mm conversion kit will fit the 12mm axle on the Surly dropouts?
    I was looking at something like this Hadley 12mm thru-axle.
    nvphatty
    Guest
    My pug is 10mm so unless the mooniie is diff the answer is negative.
    Yeah, I'm just wondering if it's a tight fit 10mm, or if there is 2mm of room to fit a 12mm for a little stronger rear. I suppose on the big balloon tires it doesn't matter anyway, not like you will notice, right?
    nvphatty
    Guest
    Quote Originally Posted by duggus View Post
    my digi caliper reads 9.95mm, hence tight fit.
    Good to know... thanks!
