Wide Tubeless Tape. Where To Buy?- Mtbr.com
Results 1 to 27 of 27
    There has been reports in a few threads of people using wide strapping tape for fatbike tubeless. The M3 8898 strapping tape in 72mm is supposed to work well **Scotch® Strapping Tape 8898
    Does anyone know where to buy this stuff? I've phoned every local shipping supply and fastener store without success. One place could order a crate but nobody carries single roles. It is the same store online. I've only found it sold by the crate.
    If I can't find anything I'll have to resort to wide Gorilla tape for my upcoming MuleFut build. It works okay but leave a sticky mess when removed.
    Can anyone advise where to buy single rolls of wide strapping tape or something similar?
    Reputation: calzonical's Avatar
    Aug 2005
    Uline
    [email protected]
    Reputation: 1strongone1's Avatar
    Quote Originally Posted by BobShort View Post
    Tyvek House wrap tape. Home Depot, Lowes or any lumber yard. Comes in 2" and 3" rolls. You will not find a lighter, better solution. I have used it on tons of fat bike set-ups, it is made to withstand the elements, unlike everything else people seem to be trying.
    "RIDE IT LIKE YOU HATE IT"
    Quote Originally Posted by calzonical View Post
    I think uline has a minimum of 12 roles if I'm not mistaken.
    Anchorage, AK
    Reputation: Lars_D's Avatar
    Amazon.
    --Peace
    Aug 2005
    U r correct.
    Well that sucks. Ordered two rolls from them back in 2013 without issue.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    (edited immediately--I was looking at cost for a case of 110m rolls, but I've now found 55m rolls that cut the price substantially.)
    I've been considering ordering a few cases of the 72mm stuff, so that I'd not only have it on-hand for my customer's builds, but so that I could provide single rolls to people in need.
    Thing is, my case cost would still require me to charge roughly $22 per roll to break even once shipping and time (to ship it here, box it up, and walk it over to Fed Ex to ship to you) are factored in.
    Would people be willing to pay that?
    I haven't been able to find single rolls online either.
    aka bOb
    Reputation: bdundee's Avatar
    Why not go with wider stuff (100mm) then people could trim to fit their needs.
    Aug 2003
    Quote Originally Posted by bdundee View Post
    That's a great question, and I had already looked into it.
    Main reason I'm against it is that trimming can be tricky, imprecise, and frustrating. Not everyone wants to fiddle with it.
    But then I also noticed that of the few places that carry the 96mm wide rolls, they mandate an 8 *case* minimum. I don't need $1400 worth of tape waiting around for people to (maybe, maybe not) purchase.
    Ordered a few cases of the 72mm stuff this AM, should see it middle of next week.
    Quote Originally Posted by 1strongone1 View Post
    good info....no issues with getting sealant to work with it? Have you tried it on a fatboy yet?
    Quote Originally Posted by mikesee View Post
    Thanks Mike! I'd definitely pay $22. Unfortunately I'm in Canada though and the extra shipping/duty/handling/taxes/exchange might make it prohibitively expensive.
    On the subject of trimming, I'd way rather not have to trim. It is hard to get a nice edge.
    On an unrelated subject, for the MuleFut, do you bring the tape right up onto the bead shelf or leave it down a bit? Any issues with leakage around the pinned seam?
    Cut the tape on the roll. Mark the width you want around the circumference then stab into it with a utility knife and follow the line. Cut a few plies deep or all the way to the core of the roll depending on your needs.
    Wonder if this would work? Amazon.com: 3M Construction Seaming Tape 8087 Red, 72 mm x 50M, 2 13/16 in x 55 yd (Pack of 1): Industrial & Scientific
    On paper, its the same stuff as tyvek and 72mm wide.
    Salsa El Mariachi SS
    Salsa Vaya
    Lurch Fatbike
    Aug 2003
    Quote Originally Posted by sven98 View Post
    Try it and let us know.
    Aug 2003
    Dunno if there'd be duty on a roll of tape? Shipping would probably be less than $10.
    I try to get the tape to touch the outer rim wall, but not go so far up it that it folds over. Delicate balance. No issues with pinned seam leakage yet, and I expected to see it.
    [email protected]
    Quote Originally Posted by barry1me View Post
    I have used it on every rim, including a set of Fatboys. I just switched out a tire today at noon and took a quick pic, HED Big Deal rim. There is just one layer of Tyvek tape and as you can see from the picture the nipple heads stick way out. There is no rim tape or strip between the heads and the tape, like on cutout rims. The tape has been in the rim for 6 months and is holding up perfect, no leakage, no protrusion of any spoke heads either.
    Attached Thumbnails Attached Thumbnails Wide Tubeless Tape. Where To Buy?-photo.jpg
    Aug 2003
    Good tip, Jeff.
    I haven't used Tyvek tape on rims, yet. But my experience with using it on boats, paddles, and other outdoor gear is that if the surface you apply it to is clean, dry, oil-free, the tape becomes more or less permanent in short order. For the repairs I use it on, that's usually a good thing. For rims, maybe not?
    Bet it'll stick better to alu than carbon, and as such I bet it's removable from carbon.
    awesome thanks for that information....which valve stems/sealant are you having the best luck with?
    [email protected]
    I have used stans and WTB stems. I use Stans sealant.
    like these?
    WTB Aluminum TCS Valve 34mm Blue Pair Tubeless Presta Valve | eBay
    [email protected]
    Yep
    Aug 2005
    R.S Hughes has 8898 and they sell individual rolls as well, however shipping charges applied after order submitted. Probably best to call for a shipping quote first or just Buy a roll or two from mikesee.
    Yep
    I just got the valves and the 2 inch wide tyvek....going to give it a try with the fatboy....
    So I want to clean entire rim with rubbing alcohol and run two strips of tyvek down the middle? then put the original tube back in, set the beads and let it sit for 24 hours to get the tape to sit nicely on the rim? Then pull out tube and put 4-6 ounces of stans in each tire?
    ok so I just tried going tubeless with my fatboy...
    I cleaned the rim inside real good with rubbing alcohol, used the tyvek 2 inch wide with three loops around the rim. I went from the edge of where tire mounts on each side of the rim and then did another loop in the middle to seal off any leakage in the middle....then installed the old tube back to get the bead to set on one side....pulled the tube out, installed my WTB presta valve, put in 4 scoops of stans sealant, inflated tire....shook tire vigorously, then did figure eights with the wheel installed on the bike for 10 minutes, then did about 1 mile of low speed riding.....tire leaks like crazy around the middle area of the rim where there are the cut outs.
    What did I do wrong? I made sure the tyvek was sealed down good, no leaks at all from the beaded area of the rims, just in the middle area by the cut outs.
    Reputation: Christ D's Avatar
    Can you post a picture of the area where the valve sits , please ?
    [email protected]
    What did you put down over the holes before you layed down the Tyvek.
    go ghetto with split tubes...
    Been there, done that....check this out.
  1. Replies: 4
    Last Post: 10-09-2014, 06:39 PM
  2. Wide Tubeless Tape
    By Sasquatch1413 in forum Fat bikes
    Last Post: 02-22-2014, 08:27 PM
  3. Tubeless & Rim Tape
    By jarango in forum General Discussion
    Last Post: 07-13-2013, 11:34 PM
  4. Light-Bikes Wide 29er hoops (rim tape)
    By rydbyk in forum 29er Components
    Last Post: 05-03-2012, 08:01 AM
  5. Stans Tape. Tubeless tape. Info needed.
    By MasterOMayhem in forum Wheels and Tires
    Last Post: 03-01-2012, 12:55 PM
