Where can I find a front hub with rear disc spacing?- Mtbr.com
Results 1 to 14 of 14
    I have an On One fatty carbon fork and I want to build a new wheel.
    Reputation: rollo's Avatar
    Quote Originally Posted by Haystack Calhoun View Post
    I have the same fork and went with one of these...
    9:ZERO:7 Rear Spaced Front Hub offered by Fatbikes.com
    Great hub. Reasonably light. Smooth bearings. Only issue is that shipping was high from Alaska.
    dying hurts.
    Reputation: johnny the boy's Avatar
    Dec 2009
    surly ultra new 135mm front disc hub.
    nice bearings and affordable.
    Jan 2015
    Agree on the Surly. I went for the 135 mm ultra new rear disc. It's 135 mm spaced, rear disc, and it can accommodate a fixed gear or a free wheel if you ever want to run it as a rear.
    Aug 2014
    I just picked up the 9Zero7 hub. Cannot beat just over $50 shipped. And in all fairness the high shipping cost is 2nd Day FedEx.
    '15 Niner Jet 9 Carbon
    '19 Karate Monkey
    Motobecane Boris
    Raleigh Willard 3, Furley & Militis 3 (SS)
    Nashbar Carbon Road
    Rippin da fAt
    Reputation: BansheeRune's Avatar
    Hope, 9:Zero:7, to name a couple. Front spaced, use 5mm spacers or a wheels mfg. spacer ring. That's a benefit to front spacing is with or without spacers it's universal.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    Aug 2014
    Quote Originally Posted by BansheeRune View Post
    Actually it is the other way around. Rear spaced hubs are universal. They can be used on front or rear spaced forks. Use 5mm spacers on rear spaced hubs and they can be used with front spaced forks.
    There is no way to use a front spaced hub on a rear spaced fork, they can only be used on front spaced forks.
    '19 Karate Monkey
    Motobecane Boris
    Nashbar Carbon Road
    Rippin da fAt
    Quote Originally Posted by blkangel View Post
    Thanks for catching that, Go figure!
    turtles make me hot
    Reputation: NYrr496's Avatar
    The 907 hub is great. I've had one on my bike for two years.
    Now... When I built my son's 907, I used a 135mm Bike Hub Store hub. I was under the impression it was rear spaced. I didn't check it before I laced the wheel. Built the wheel, went to put it on the bike, brake rotor was too far inboard to go into the caliper.
    I took the caliper adapter and filed it where it bolts to the fork. Got it to work. This was going to be a temporary solution until I could re lace the wheel but it's given us zero problems so I'll leave it until he out grows this frame and moves up to another, probably with 150mm spacing.
    I like turtles
    Reputation: funnyjr's Avatar
    Quote Originally Posted by NYrr496 View Post
    What you mean is the rotor was too far OUTBOARD since it is front spacing. If it was too far inboard it would be rear spacing.
    Just FYI they actually manufacture an brake adapter similar to what you hacked up to convert front to rear spacing provided you upsize rotor to at least 180.
    turtles make me hot
    Quote Originally Posted by funnyjr View Post
    I stand corrected. I had to go look at the bike to be sure. Yes... I saw that adapter but no one was going to have that thing in stock and we were excited to go riding that day. I had just been given the ok to get back on my bike after a broken ankle.
    I filed a 180mm adapter so we could have just bought the aftermarket one if we needed it.
    I like turtles
    Rippin da fAt
    Gotta give the bloke credit, he was jonesin' to ride a bike!
    Reputation: mtuck1's Avatar
    I just got one of these forks also and wound up going with I9 primarily because my rear hub is I9. 135mm, 10mm axle, QR, and rear spacing, no problem. They don't sell many but it was on the shelf and just waiting to be anodized whatever color the customer wanted. It was shipped 2 days after I called and at my door 2 days after that. Admittedly not the cheapest alternative though.
    Attached Thumbnails Attached Thumbnails Where can I find a front hub with rear disc spacing?-dscn2614.jpg
    Reputation: jlynn907's Avatar
    Oct 2013
    $36 plus shipping -- hope this helps, and best of luck with your build!
  1. help: 20 inch wheelset, 126mm rear spacing, disc
    By ifouiripilay in forum Families and Riding with Kids
    Last Post: 07-10-2015, 11:43 AM
  2. Replies: 1
    Last Post: 04-14-2015, 04:33 AM
  3. Specialized Fatboy front hub disc spacing?
    By the mayor in forum Fat bikes
    Last Post: 03-12-2014, 06:05 PM
  4. Replies: 21
    Last Post: 07-01-2013, 11:16 PM
  5. Spot mod disc rear hub spacing
    By Bald_Ben in forum Cyclocross
    Last Post: 02-10-2013, 10:59 PM
