When you're in-between sizes on Surly fat sizes (S or M?)- Mtbr.com
Results 1 to 6 of 6
    May 2017
    Hey all -
    I'm absolutely new to mountain biking. I really want to get into bikepacking and the idea of investing in a surly fat bike with the option to add 29ers sounds about perfect. From my research, the Pugsley seems to fit the bill.
    My measurements seem to fit smack dibbity dab in the middle between a Small/16 and a Medium/18 frame. Iím 5í8 1/2 , 32 Ĺ inseam. Female, but that probably doesnít matter. On paper a Medium seems to fit the bill Ė but on paper a 54cm road bike seems to fit the bill but Iím just WAY too stretched out. Iíve realized Iíve been riding a [road] bike for 3+ years thatís been too big for me, and I donít want to make the same mistake when purchasing a mountain/fat bike. And because I seem to be in-between sizes, Iím asking for advice.
    FWIW Iím aware all manufacturers have different measurements (center-top vs. effective TT), which makes the comparison between a 54cm Specialized road bike and a Surly mountain bike virtually useless.. Iím just looking for personal experiences and opinions, especially from those who use their rig to bikepack.
    Iím leaning towards a small, as I know itís easier to compensate a smaller frame than a larger one. Also, because Iíll be bikepacking I imagine a more relaxed position would be best.
    Thanks so much for the input! Really appreciate it.
    Reputation: Velobike's Avatar
    I buy one size down in fatbikes - mainly for standover in soft conditions, eg snow, or mud.
    Doesn't seem to be a problem.
    Any bike, anywhere, anytime.
    Latitude: 57ļ36' Highlands, Scotland
    Co Springs
    Reputation: bachman1961's Avatar
    Oct 2013
    When you say you are female, it probable does matter or can. Look up typical female fit to bike characteristics just to be safe. I recall women having a slight dif in proportions like legs trunk arms... it might be good to know or help some.
    I was looking at med and large and felt between but a few sample rides helped and stem, bar and saddle all allow some detailed fit parameters. Good luck.
    "Before you criticize, you should walk a mile in their shoes. You'll be a mile away from them and you have their shoes"
    Jan 2013
    Women typically have long legs and short torsos. There is no right answer until you sit on the bike. A small may leave you with a ton of seat tube out and proportionally lower bars than you would like. A medium may have you to stretched out. Short stems on in vogue now for good reason. I would try a medium with a short stem and see if it can work for you before ordering anything. Most shops can swap out a stem in 5 minutes before you commit to buying.
    Oct 2016
    I would ride a medium. I am male, but close to your size, 5'9 with a 31" inseam (so more upper body). I like 545-555 ETT on a road bike, with a 90-100mm stem.
    You will probably be happier on the small, even though the ETT is only 15mm shorter than the medium.
    Reputation: blekenbleu's Avatar
    Aug 2016
    future tires
    Quote Originally Posted by Blood_and_Mustard View Post
    ...Iíve realized Iíve been riding a [road] bike for 3+ years thatís been too big for me, and I donít want to make the same mistake when purchasing a mountain/fat bike.
    If there is a chance that you might eventually want to mount larger tires, they can effectively change standover by that much.
  1. Surly 1x1 widest tire rim sizes.
    By biker_eric in forum Fat bikes
    Last Post: 12-01-2017, 02:03 PM
  2. surly bikes and sizes?
    By bavli1 in forum Bikepacking and Bike Expedition
    Last Post: 03-07-2017, 03:06 PM
  3. about surly bikes and sizes?
    By bavli1 in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 02-17-2017, 03:24 PM
  4. Replies: 4
    Last Post: 01-20-2017, 11:34 AM
  5. Between sizes. ....
    By jeremyreed in forum General Discussion
    Last Post: 03-07-2014, 02:52 PM
