What is the widest fat bike wheel available?- Mtbr.com
Results 1 to 25 of 25
    Feb 2018
    Iím currently running 100mm but could use even wider wheels. Are 110mm available like this guy mentioned in his article? https://expeditionportal.com/the-wid...n-bike-wheels/
    I didnt come come up with anything in the google searches I tried. The biggest Iíve found so far are 105mm carbon rims by Nextie and I believe Kuroshima which are very spendy. I ride for recreation and fitness so bike weight isnít my primary concern. If there is a less expensive aluminum wheel thatís wider than 100mm Iíd be interested in hearing about it.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I think mikesee is on 217mm hubs is you want wider wheels.
    I don't recall any aluminum rims wider than 100. If there were, I'd expect them to be a little pricey too.
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    105 mm in carbon Kuroshiro and Nextie.
    :thumbsup:It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    turtles make me hot
    Reputation: NYrr496's Avatar
    What are you running for tires? Will your frame hold Snowshoe XXL's?
    I like turtles
    Feb 2018
    Yes, this is my 3rd season on 2XLís mounted on 100mm wheels. We finally decent snow last week and even though we only have around 18Ē on the ground, it isnít compacting super well and I often break through the packed, thin, crusty layer on the set up, low traffic trails. I want to go wider just wondering what options there are? The 105ís are what I keep seeing as well and Iím struggling to justify the exorbitant cost for an extra 2.5mm per side over what Iíve got presently. I was hoping there were 110ís available but Iím thinking the guy who wrote the article must have been mistaken.
    turtles make me hot
    Maybe I'm wrong but I just don't see 5mm or even ten on the rim making a profound difference. I'm sure you're running the tire pressure as low as possible to try and float.
    I like turtles
    Reputation: Velobike's Avatar
    132mm wide rims at Classic Cycles
    https://classic-cycle.com/all/151/al...ck-matte?c=419
    Any bike, anywhere, anytime.
    Latitude: 57ļ36' Highlands, Scotland
    Quote Originally Posted by Velobike View Post
    Now you just have to cut and stitch together a couple of 2XL's for a 150 mm tire and off you go.
    Latitude 61
    Reputation: ADKMTNBIKER's Avatar
    Nov 2014
    now that's fat
    Reputation: BlueCheesehead's Avatar
    Finally, a rim to make tires true to size.
    I would think a build with those would suck. Spoke angle would be minimal.
    Oct 2007
    Quote Originally Posted by sryanak View Post
    Just go with this tire: CHAOYANG TIRES-YETI CROSS
    Awesome!
    A 1500 gram rim!( that's 3.3 pounds)
    Can the admins merge this with the thread where people are saying light wheels are more important on fatbikes than any other bikes?
    Quote Originally Posted by BlueCheesehead View Post
    It's not all about the angle.
    You have to consider the dangle.
    #danglematters
    Quote Originally Posted by grisha View Post
    And there I was wondering what on earth use a 132mm rim was.
    That would be some combo.
    Can't get those tyres in the UK AFAIK, otherwise...
    If those are the tires they had at the Taipei show last year....they ain't even close to being 5.5s
    turtles make me hot
    Ha! I just assembled a 20" fat bike for my nephew for Christmas and the 100mm wide wheelset was horrifyingly heavy. I scoured the internet for ANYTHING 20" diameter, 70 or 80mm width and 32 holes. No dice. I put the bike together as is. Junk.
    Anyway, what frame is the OP riding that can use all of this huge stuff?
    I like turtles
    Feb 2018
    Quote Originally Posted by the mayor View Post
    Sounds like they must be using the same penis measuring ruler that 45 North uses. I have a set of Chaoyang 4.9Ē tires that came on one of my old bikes. They donít even come close to being 4.9Ē wide.
    This is interesting to find out about whatís out there. I wonder how wide a 2XL would be on a 132mm wheel? Iím thinking there probably isnít much to be gained as the 2XL is only slightly ballooned on a 100mm rim. A 132mm would be nice with a larger, wider tire but Iím thinking that gets you into much wider hubs than standard or going with an asymmetrical frame like a Moonlander or doing something weird with the chain line to clear a tire that big like a true 5.5.
    Reputation: AllMountin''s Avatar
    That rim has a lot of room for weight loss, if one was ambitious enough. People used to do it before manufacturers were cutting them for us.
    I could probably use it. My suspension fork fits a 2xl comfortably enough side to side(RST Renegade), but doesn't quite fit under the arch without binding. I reckon this rim would give me extra width, and pull the height down enough for clearance. Win win.
    Still not buying it though.
    Quote Originally Posted by Snowfat View Post
    t
    I use the penis measuring ruler that has been around since the first issue of Penthouse Forum.
    "Dear Penthouse Forum,
    I never thought I'd be writing to you.....
    I am an average man of 13" length...."
    Quote Originally Posted by AllMountin' View Post
    I could probably use it. My suspension fork fits a 2xl comfortably enough side to side(RST Renegade), but doesn't quite fit under the arch without binding. I reckon this r.
    Every one started laughing when you said RST Renegade.
    And just like that....this thread turned into a shitshow.....
    Apr 2005
    what kind of frame can handle 5.5 inch tire?
    Feb 2018
    Aside from the Surly Big Fat Dummy nothing at the present time. I bet if they were available for sale some company would build a frame that fit them.
    Iím still looking for the 110mm aluminum wheels the guy mentioned in the article.
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Quote Originally Posted by Picard View Post
    Iíve got 2 custom Meriwether frames and forks that can fit a true 5.6Ē tire on a ~120mm rim. Key word = custom.
    Reputation: BikesOnSnow's Avatar
    Woah! Might have to order one, if I can find a frame it fits. Drilling some big hole saw holes to save weight wouldn't be that hard. Done it before and would be worth doing again on these.
    Found this older thread on them too: https://forums.mtbr.com/fat-bikes/26...m-1008150.html
    In the summer I build trails: www.sinuosity.net
    In the winter I build these: www.fatbikeskis.com
    Feb 2018
    Good find!
  1. Fat bike wheel set or Mid fat bike advice
    By stldlr in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 09-08-2017, 06:56 PM
  2. Fat Wheeled Fat Bike Third Wheel Trailer
    By Fikas Bikas in forum Fat bikes
    Last Post: 06-26-2016, 06:22 PM
  3. Karate Monkey widest wheel/ardent
    By Philthyssvirgin in forum Surly
    Last Post: 05-13-2014, 06:49 PM
  4. What is the widest 29er tire available?
    By ccornacc in forum 29er Bikes
    Last Post: 10-27-2011, 01:16 AM
  5. fat fat fatty fat fat fat
    By evilbeaver in forum Riding Passion
    Last Post: 12-10-2006, 01:23 PM
