What dropper post for winter???????- Mtbr.com
Results 1 to 15 of 15
    May 2017
    Hey guys, I am looking for a winter dropper.
    What I tried before:
    - Reverb: died at -20c
    -Fox transfer: : died at -20c
    -E13 trs: had many problems, spring was too soft etc
    -Specialized command post: current. It’s not smooth and hate the 4 positions, sometimes it get jammed in beetween 2 notches..
    Basically, I want to know if there is a post as smooth as the Fox Transfer but holds in -30celcius temps.
    Needs to be internally routed and infinite adjustment. Not 3-4 positions, hate that.
    Any thoughts??
    Envoyé de mon iPhone en utilisant Tapatalk
    Giant. I use mine down to -40c no problems. And they are cheap. They only come in 30.9 but work fine on 31.6 with a shim.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    You want mechanical and easily rebuildable. I'm running a transfer, but I already killed it once about 2 weeks after I got it. I run bikeyoke revives on my other bike and they are absolutely mind-blowingly good. Would they work in cold temps? I don't know, the coldest I get with them is about -10c. While riding they work great, but you do run into a little issue bringing them in from the cold, if you leave the post full-up it is real hard to actuate the lever when the post warms up, so you are advised to leave the post partially compressed when changing temp/environments. It's only a little annoying, but the greater the difference, the bigger of an issue this becomes, making me think this is not the best post for extreme cold. PacNW is mechanical right? Mechanical and user-serviceable/rebuildable are the most important things IMO.
    beater
    Reputation: evasive's Avatar
    Feb 2005
    PNW does have a coil-spring dropper, yes. I’ll be putting one on my fatbike this winter.
    BikeYoke Divine SL has held up fine down to -28c.
    The White Jeff W
    Reputation: jeffw-13's Avatar
    Quote Originally Posted by evasive View Post
    I had a PNW Cascade on my old Farley. Always worked well but I rarely rode below 20* f
    Bought another one for my new Farley.
    No moss...
    Reputation: JeepRage's Avatar
    Oct 2017
    My Brand-X has been trouble free for 1.5 years on my fatty. Simple and inexpensive.
    I have a Reverb that came on my FS and notice it slowing in the winter but I try not to under 10 degrees.
    Sent from my Pixel 3 using Tapatalk
    2017 Santa Cruz Tallboy C 29er
    2018 Canyon Dude fatty with Mastodon
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    I've had the Giant and the Bontrager down to about -20*f. Both worked fine.
    Both seem to use the same replaceable cartridge.
    Reputation: CanuckMountainMan's Avatar
    Oct 2018
    Bontrager Line Dropper for me too, no issues at all. (-20ºC)
    2020 Trek Farley 7 Roarange
    2018 Trek Farley 7 ViperRed
    Wanna ride bikes?
    Oct 2013
    SDG Tellis works great at low temps. I believe it's similar to the Giant and a couple others.
    Cheap and easy to replace cartridge. Very light action lever.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Reputation: brentos's Avatar
    I've frequently run my Crank Brothers Highline down to -25C (-15F) with no issue. It's a great post overall.
    My criteria would include reliability shown over at least two seasons of sub-freezing temps
    May 2017
    Thanks guys!!
    rth009
    May 2010
    I used a PNW Cascade 150mm 30.9 external last winter and had no issues with the cold down to single digits on a few occasions.
    Reputation: solarplex's Avatar
    Apr 2014
    Anyone use the pnw ranier?
    Fatbike, XC bike, Gravel Bike....
  1. Replies: 3
    Last Post: 08-28-2018, 12:05 AM
  2. Replies: 28
    Last Post: 07-05-2018, 11:37 AM
  3. Cheap-ish dropper post for winter use?
    By Vegard in forum Components
    Last Post: 09-15-2016, 05:57 AM
  4. Help me finish my Mach 6 (Dropper Post Post)
    By trickbooter in forum Pivot Cycles
    Last Post: 05-28-2014, 11:34 AM
  5. Replies: 5
    Last Post: 01-13-2005, 09:55 PM
Members who have read this thread: 105
