Wampa Wheel issue.- Mtbr.com
Results 1 to 3 of 3
    Wampa Wheel issue.
    Has anyone experienced a leaky valve stem on the Carbon Wampas? I have a leak at the valve stem. I hand tighten the small nut but still leaks. Im set up tubeless. I replaced the valve stem and cleaned the inside and outside of the wheel to make sure there were no Stan's buggers, and still leaks. I guess the next step is to re-tape the wheel. Anyone else have issues like this? I have a tube in the wheel, but I swear the tube weighs almost 2lbs. BK
    This place needs an enema
    Reputation: mikesee's Avatar
    Aug 2003
    Replace the tape. Don't *poke* a hole for the valve stem, *melt* it through. I use an old spoke and a cigarette lighter. How you arrive at a hot pointy piece of metal is irrelevant -- just be sure the hole you melt though the tape is uniform.
    I threw in a Stans valve stem and issue went away. I cracked the Wampa last night, not happy. BK
  1. Trek Cobia Wheel Issue
    By Gonzoso in forum 29er Bikes
    Last Post: 05-12-2013, 10:00 AM
  2. The Mukluk of Wampa Treads at Treeline
    By mountaingoatepics in forum Colorado - Front Range
    Last Post: 01-23-2013, 02:06 PM
  3. Wampa Hunting at Treeline..a Custom Mukluk Build
    By mountaingoatepics in forum Fat bikes
    Last Post: 01-23-2013, 09:33 AM
  4. Wheel Flex Issue
    By fredfredburger in forum General Discussion
    Last Post: 03-12-2012, 08:53 AM
  5. Front wheel issue
    By Eric Z in forum Beginner's Corner
    Last Post: 07-04-2011, 10:37 AM
