Ventana El Gordo Cable Routing- Mtbr.com
    rth009
    May 2010
    I'm trying to get my El Gordo built up and I cant figure out the cable routing , especially for the front derailleur. The bikes I've built have all had the under the bottom bracket, non-full housing, setup. This one has the cable stops on top of the downtube. My front derailleur is a shimano xt direct mount that is supposed to work bottom or top pull, but I cant figure it out. Seems like it has to come from the bottom considering where the cable stop is. Can anybody post a pic of their El Gordo front and rear derailleur cable routing so I dont have to go to the LBS in defeat?
    rth009
    May 2010
    It does help. thank you very much. Did you use the shimano sealed end caps with tube and shield on the front derailleur?
    Nope.... Just std. cable. Everything works fine.
    Enjoy your Gordo... Best fat bike frame I've ever ridden.
  1. Ventana El Gordo
    By Tripower in forum Fat bikes
    Last Post: 12-07-2015, 03:04 PM
  2. Ventana El Gordo
    By cbrossman in forum Fat bikes
    Last Post: 01-03-2015, 02:06 PM
  3. Ventana El Gordo Build Complete
    By bogmonster in forum Fat bikes
    Last Post: 11-01-2014, 11:58 AM
  4. Cycle Monkey and Ventana partner for El Gordo
    By Berkeley Mike in forum Fat bikes
    Last Post: 08-21-2014, 09:26 PM
  5. Xpost from Ventana Board - Ventana El Gordo Pics..
    By Ciclistagonzo in forum Fat bikes
    Last Post: 02-25-2014, 02:39 PM
