Un-holey Darryl/Floyd tubeless- Mtbr.com
Results 1 to 3 of 3
    I've followed the tubeless discussion with the hope of going fat-tire tubeless myself.
    For me the goal is 90% flat avoidance.
    So, it was actually very simple. First time bead seated!
    Un-holey Rolling Darryl + Black Flloyd (gravel use)
    Rolling Darryl rim strip.
    One path, on center, of duct tape (the darryl strip runs around 1/4inch beyond the sides of the of the duct tape).
    Inflate a tube to seat the beads.
    Deflate tube and, leaving one bead seated, remove the tube.
    Insert stans valve stem.
    IMPORTANT: remove the valve core and inflate to seat the beads. With the valve core removed air from the compressor can blast in to seat both beads in 3-4 seconds. Air will of course roar back out, but the beads are seated.
    Four ounces of stans through the valve stem.
    Insert stem core.
    Inflate and do the tubeless jiggle/swoosh.
    Never deflated, and retained full pressure - 18lbs.
    First ride tubeless I had a puncture. Rotated tire for stans to do its job. Back riding to do a short 25 mile gravel ride.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Nice!
    Reputation: ChevyM14's Avatar
    very cool, never thought of putting air in with out the valve core to seat the bead. going to try that with I do my tubless convert on my BFL. thanks
    2012 FatBack with BFL tires
    2010 Specialized StumpJumper FSR Expert
    2006 Specialized RockHopper
