Tyre Pressure Question- Mtbr.com
Results 1 to 8 of 8
    Reputation: drofluf's Avatar
    Dec 2010
    New question here. Tyre Pressure Question
    Just fitted the tyres for the first time - Endomorphs on Fat Marge rims and had to put them to over 20psi before it felt that the tube was 'filling' the tyre which was higher than I expected.
    Is that about the right pressure to start with?
    Is it OK if the tyre moves on the tube?
    If you need me I'll be at the bar
    is buachail foighneach me
    Reputation: sean salach's Avatar
    1- It's not ok if the tire is loose, or moves on the tube.
    2- 20 is a little high to start with. 14-16 would be a better starting point.
    Try letting the tire/tube sit at 20 psi over night. The tube should stretch out and fill the tire better. If it doesn't, you might need a new tube, possibly a different brand.
    Reputation: Velobike's Avatar
    What sort of tubes? I don't have this with the Surly tubes, but when I use smaller diameter ones, then as per Sean.
    Latitude: 5736' Highlands, Scotland
    Dec 2010
    Thanks for the replies.
    Sean - I've left them inflated so I'll see in the morning
    Velobike - I'm not sure, they came with the bike which I got on eBay and picked up yesterday. My guess is Surly since everything else is....
    Of course the other thing could be the gauge on my pump, I'm not sure how good that is
    Geordie biker
    Reputation: saltyman's Avatar
    It's common for them to appear loose until about 5psi onwards, intend to inflate to 10-15psi when sticking new tires on and leaving them or go for a ride straight away to seat them.
    20psi seems a tad much to get them to settle in place, they must be normal or dh tubes and not surlys?
    2014 milage so far - 2,485
    www.ukfatbikes.co.uk
    Reputation: GTR2ebike's Avatar
    May 2010
    You probably need bigger tubes. 20 psi is for ridding pavement, tire pressure is everything.
    Nov 2007
    Quote Originally Posted by GTR2ebike View Post
    I totally agree. For me, there's a pretty strict "sweet spot" that makes the whole fatbike experience. It's around 6-7 psi.
    Perpetual n00b
    Reputation: dgw2jr's Avatar
    Quote Originally Posted by SmooveP View Post
    Agreed. 6-7psi is perfection.
