Tubeless ready Bud & Lou- Mtbr.com
Results 1 to 11 of 11
    Anyone mounted the new versions up tubeless? Easier than the originals? Surely must be....please....
    urmb
    “How inappropriate to call this planet "Earth," when it is clearly "Ocean.”
    ― Arthur C. Clarke
    one chain, two sprockets
    I’ve had a new tubeless Bud for close to a month. It set up super-simple, no soapy water, just inflation to set the bead then pumped-in 4oz. of Orange Seal Subzero. It holds set pressure fine as well.
    This is my first Bud, and it really is a great tire.
    Nov 2014
    Did surly revise the bead on the Nate as well?
    Rippin da fAt
    Reputation: BansheeRune's Avatar
    The best part of this drama... Bud, Lou and Nate are muchhhh cheaper in the original version!!!
    If anything, the originals had a looser fit and soap was obsolete.
    Get fAt, Stay fAt, Ride fAt
    Doctor recommended...
    Dec 2017
    I have had the old Bud and Lou for years and never even knew they weren't tubeless compatible. Mine have been tubeless from day one; I've never ridden even a single mile on them with tubes in the tires. I have two friends with Nates, same for them, tubeless only.
    Reputation: watermonkey's Avatar
    The only reason I'd spend the extra money on the new ones vs. the old ones is if they came with stud pockets. Grip studs are great and all, but it gets old screwing them in. I don't know if I'll ever ride anything other than a studded Bud and Lou. If I need a bigger tire, I'm going skiing anyway.
    I would advise not taking my advice.
    rth009
    May 2010
    Quote Originally Posted by twodownzero View Post
    I have done the same, but the gripstudded Lou on the rear will burp if the pressure gets as low as Id really like to go for the really soft stuff.
    Dec 2017
    Quote Originally Posted by rth009 View Post
    I doubt the new ones will be any different in that regard.
    May 2017
    This me too. On mulefut 80 wheels. Been riding these for 2-3 winters tubeless without one problem. I don’t even refresh the scealant.
    Envoyé de mon iPhone en utilisant Tapatalk
    Rippin da fAt
    I think the new "tubeless" tire will feature a tighter fit than the original version. My two pair are rather loose fitting and needed two wraps of tape to tighten up the fit for the 1.5 PSI that a powder day requires. No studs cause there's no need in the backcountry at 10-11k elevation.
  1. Replies: 0
    Last Post: 10-11-2018, 10:36 AM
  2. Clown Shoe, Bud, Lou, tubeless...Help.
    By SeattleJP in forum Fat bikes
    Last Post: 12-17-2016, 08:40 PM
  3. Bud and Bud, or Lou for sand?
    By letitsnow in forum Fat bikes
    Last Post: 04-02-2016, 04:02 PM
  4. Replies: 4
    Last Post: 05-30-2015, 10:03 PM
  5. Until such time I get my 4.8" Bud and Lou running tubeless…
    By Leopold Porkstacker in forum Fat bikes
    Last Post: 08-09-2014, 07:03 AM
Members who have read this thread: 72
