tires- Mtbr.com
Results 1 to 21 of 21
Thread: tires
    tires
    looking to buy a 29 inch wheelset.I need help with tires.Usage will be gravel and some single track.Any suggestions?
    Quote Originally Posted by bnelson View Post
    Any suggestions?
    I suggest you have a few more cups of coffee before creating threads.
    bigger than you.
    Reputation: Gigantic's Avatar
    Try the 29er sub-forum
    Reputation: CHIEF500's Avatar
    29" used to be fat.
    Reputation: Swerny's Avatar
    ask in the 29'er or better yet, the "Wheels and Tires" section
    Mike
    Toronto, Canada
    2017 Trek Farley 9.6
    2017 Diamondback Haanjo Trail Carbon
    2016 Scott Solace 10 Disc
    Reputation: tyriverag's Avatar
    Jan 2014
    Considering your intended usage, I'd likely go with
    it's a challenge some of us are ultimately worthy of.
    Reputation: watts888's Avatar
    Oct 2012
    In all honesty, just get some cheap 29er tires. doesn't sound like grip or tread pattern is all that important to you, and the cheaper tires usually have heavier denser rubber which will list longer on gravel/road use, but still work fine for casual trail riding.
    Thin Man on a Fat bike
    Reputation: SAM313's Avatar
    Quote Originally Posted by jonshonda View Post
    But then again..........A little verbal abuse in the morning can get your blood going too, perhaps he's out of coffee and just baiting us
    Quote Originally Posted by SAM313 View Post
    Ahhh, you're saying he may be a Master Baiter?
    this is almost becoming the roadbike forum
    i am getting a 29 inch wheelset for my fat bike as was looking for tire suggestions.Why would'nt I aske this on the fat forum?
    Reputation: solarplex's Avatar
    Apr 2014
    i like my specialized ground controls 29x2.1s. they roll fast and grip everything. wear is great as well. they are firm tho. if you want some squish get the 2.3s. what fat bike you putting these on? can you buy wide hub wheels or do you need to make your own?
    Jul 2014
    I've been pleased with Maxxis Ardent EXO's- they hook up well and mounted up tubeless easy. Have been very durable thus far. I'm running the 2.4" on my Fuel.
    19 Fargo Ti
    '17 Cutthroat
    '15 Fatboy Expert
    Mar 2014
    Probably because you failed to mention that it was a wheelset for your fat bike in your original post.
    so you have no suggestion on tires
    why would i post in fat bike forum
    Mar 2015
    700 x 25c maxxis refuse (wicked grippy tires) @ 95-105 psi depending on how fat you are, or not. I run these tires on my kona jake the snake and they slay dirt/gravel roads and moderate singletrack. way more fun than mtb or even cross tires for said conditions. Then when you pop out on the pavement, the 240 +- gram tires slay that too.
    looking fot suggestions for a fat wheelset 50mm wide
    Mar 2015
    I know guy, i'm not even drinking. I was just letting you in on the fact that road bike tires on a road or cross bike can be way more fun for the conditions you seek.
    very truebut nothing beats the comfort of all day fat bike ride
    Mar 2015
    I won't disagree there.
  1. Putting slimmer tires in a frame made for wider tires?
    By bowlofsalad in forum Fat bikes
    Last Post: 09-01-2014, 04:04 AM
  2. Replies: 2
    Last Post: 10-31-2013, 08:33 AM
  3. Switching from off road tires to street tires...suggestions?
    By bpreachers in forum 29er Components
    Last Post: 04-13-2013, 10:35 PM
  4. Replies: 4
    Last Post: 10-07-2011, 05:04 PM
  5. Wider tires, less rolling resistance, what about taller tires
    By HighLife420 in forum Wheels and Tires
    Last Post: 06-01-2011, 06:23 PM
