Tire setup questions- Mtbr.com
Results 1 to 6 of 6
    Aug 2014
    I've got two questions and I might as well combine them into one thread.
    I just bought a fatbike with bud and lou's. So I deflated the tires and pulled them off to change my rimstrip to something a little bit more fun. I got the tires back on okay and inflated the tube back up. My question though is around a small amount of my tire the bead hasn't fit back in. No matter how much I try to work at it with my hands i can't get it to bump back into place. What do I do here? Do I just keep inflating the tube until it fully goes in and then let out the pressure? I haven't bought a pressure gauge yet so I really don't know what i'm at right now. I've been going off of feeling.
    Second question
    I bought my bike used and I found that my rear tire has a small hole in it. With a tube it's fine but I've been wanting to try and run a tubeless setup. Is it even worth attempting with the small hole or would I need to buy a new tire? I'm not very familiar with how stanz and other tire sealants work or how well they seal up holes.
    Sometimes I can pump the tire enough to seat.. I can hear it snap in.. Other times I have to roll it around on the concrete for a bit. About the hole, thats what the sealant is for. You could patch it from the inside though.
    Sent from my 831C using Tapatalk
    Reputation: rex615's Avatar
    Aug 2014
    Quote Originally Posted by ou2mame View Post
    Is this a common issue, small holes in tires?
    Since I have never set up a tire as tubeless, my tires could have had small holes and I guess I would have never noticed it.
    Reputation: thickfog's Avatar
    Oct 2010
    Re: Tire setup questions
    Get in the habit of lubing the bead. Soapy water, windex, Uncle Dick's bead lube, etc.
    They'll pop right on.
    CRAMBA Chairman
    nvphatty
    Guest
    Quote Originally Posted by thickfog View Post
    and if need be up to 35psi.
    I don't think anyone can tell you if Stans can plug a 'small' hole. I think a photo and /or a measurement is in order.
  1. New tire setup questions....
    By gregnash in forum Wheels and Tires
    Last Post: 04-21-2014, 11:10 AM
  2. Some setup questions
    By foulhabits in forum Downhill - Freeride
    Last Post: 06-15-2012, 12:16 AM
  3. Replies: 4
    Last Post: 04-18-2012, 10:48 AM
  4. good tire size setup? new tire suggestions
    By ryin in forum Wheels and Tires
    Last Post: 03-09-2012, 04:25 PM
  5. V10 setup questions
    By Lucrativesoldier in forum Santa Cruz
    Last Post: 02-09-2012, 06:11 AM
