tire bead woes- Mtbr.com
Results 1 to 8 of 8
Thread: tire bead woes
    tire bead woes
    Hello All -
    Been mtn biking for a decade or so, had more or less every kinda mtn bike known to man, but new to fatbikes.
    Bought my first one last year, totally hooked. Just finishing up a build on a second this year.
    Onto my question: needed to put tires on rims (new build, and replacing worn-out ones from the prev winter) - and with both set, the beads just dont seem to want to push all the way into the corner of the rims, leaving the tires unbalanced.
    I'm running tubes, so I'm real concerned with leaks, its more of the uneven wearing and just the annoyance of feeling a tire being off balance
    any tips for this? honestly I cant ever remember encountering this problem with any other tires and rims in the past, but within the span of a week - 2 brands of tires, two brands of rims, exact same result.
    Intense Carbine C
    Intense Spider 29 C
    Ventana El Comandante
    Borealis Yampa
    9:Zero:7 Al
    Soma Wolverine
    Surly LHT
    Rocking on a Rocky
    Reputation: RockyJo1's Avatar
    Did you give them some soapy water? I even used olive oil once. Pump to max psi.
    It doesn't matter what I ride as long as I ride it Rubber Side Down●~●.
    All fat, all the time.
    Reputation: Shark's Avatar
    Feb 2006
    Lots of soapy water, more than you think you'll need. Sometimes a short ride helps pop everything into place.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    I've had this problem with tubed tires, tried a lot but couldn't get it perfect. No such problem with tubeless.
    Nov 2008
    Never had a tire I couldn't get to fully bead out with enough soap and air pressure.
    Rims and tires used? And if new build, why not tubeless?
    since 4/10/2009
    Reputation: Harold's Avatar
    For me, straight liquid dish soap works far better than soapy water.
    Professional Crastinator
    Reputation: Fleas's Avatar
    ...or Windex.
    -F
    Quote Originally Posted by lifeis11 View Post
    ... the beads just dont seem to want to push all the way into the corner of the rims,...
    PS - getting the tire beads "in" all the way is not necessarily how the tire should fit. Just check that line near the bead is the same distance from the rim all the way around.
    It's never easier - you just go faster.
  1. 27.5+ tire Bead to Bead measurements
    By bikeny in forum 26+/27.5+/29+ Plus Bikes
    Last Post: 08-11-2018, 07:07 PM
  2. Bead to Bead Mtb Tire Measurement
    By Deerhill in forum Wheels and Tires
    Last Post: 06-05-2018, 02:18 AM
  3. Tire bead sizes...REALLY???
    By tigris99 in forum Wheels and Tires
    Last Post: 01-31-2015, 10:51 AM
  4. fat tire bead set evenly
    By slayer30 in forum Fat bikes
    Last Post: 04-23-2014, 04:06 AM
  5. Wire bead tire on UST rim?
    By Jet Fuel in forum Wheels and Tires
    Last Post: 10-24-2011, 04:17 PM
